DC5R brakes questions
Will the DC5R's Brembo brake calipers & discs direct bolt on to RSX-S? And u just need the DC5R 17" rims or other right size & offset rims to clear the calipers I think?
TIA for all the info.
i'm pretty sure it will be a direct change over ....but the JDM 17's or any aftermarket 17 inch wheels will have ot be used for clearence of the calipers...now if the Dc5-R uses a different Brake master cylinder or lines...that i dont know...btu its possible
WhosITR: Cool what kinda offset is your K1?
Thanks for the info guys
it is 42off set on this K1 16X7.5 ,but the brake is not fit in,have to do some work on the rotor,because the rotor have off set diff TYPE-S and TYpE-R.
First thing, I got the Type R front bearing hub rotors and brake caliper. I don't have to modify the brakes to fit the rims. That means if you buy a Type R from Japan, it will still fit into these K1 16x7.5 rims.
