D15b7 lag?
Old Sep 9, 2010 | 05:25 PM
d16z6EG's Avatar
Icon2 D15b7 lag?
Ok I got a 94 civic ex auto for my girlfriend and it needed a headgasket I replaced it and put everything back together and no overheating seemed to good. The PCV valve broke but wasn't throwing any codes and about week or two started to have trouble getting up hills and just got worst from there. I replaced the pcv valve and only made it worst. It sounds like it backfires in the manifold idk how to explain the sound. When it picks up it's fine it's mainly on hills and initial starting the timing is at tdc both with the service connector jumped and with it not it won't go any further for 16 btdc. Idk wat else could it be the head is bad? I have another on now but don't want to switch it if unnecessary. Anyone have suggestions
Old Sep 10, 2010 | 04:09 PM
d16z6EG's Avatar
Default Re: D15b7 lag?
ok so checked the timing again and with the connector jumped it will not even get colse to the 16 btdc mark its ether at the tdc mark, before it or after. and its turned to the fullest is the distrubutor maybe taking a ****? and stilll throwing no codes wtf????
Old Sep 11, 2010 | 09:23 PM
megomaniac's Avatar
https://honda-tech.com/forums/tech-misc-15/ignition-timing-way-off-help-pls-2833576/
Old Sep 12, 2010 | 10:27 AM
LyveMyche's Avatar
First make a mark on the timing belt and the timing gear so that you can see where you started from. Then easily slide the belt off of the timing gear and advance the camshaft 1 tooth. back your distributor off and then try to drive it again. If its a tooth out it will run like dog ****. I had to back my timing off last year to get it to pass emissions. I drove it over there like that, it ran terrible...
Old Sep 12, 2010 | 01:17 PM
d16z6EG's Avatar
Thanks will do asap well was messing with the distributor and relized that the fire order is goofy. So I looked it up and it's the wrong the distributor it's off a 8 valve. Going to get the right one tommorrow. this the whole reason it's *******?
jmille25
Jul 30, 2015 02:18 PM
Raymond94
Feb 28, 2012 06:04 AM
Mike Fussell
Honda Motorcycles
Jul 17, 2011 12:52 PM
waciii
Oct 13, 2008 09:24 AM
hybr1d_rac3r
Mar 8, 2004 05:04 PM
