90 integra idle problem help me anyone
Old Sep 9, 2010 | 12:42 PM
kingjames0509's Avatar
Default 90 integra idle problem help me anyone
when my car idling its fine when i shift from 1st to 2nd it stalls out then i let go clutch and it jumps itself only when i hold clutch down and dont shift it cuts off if i shift quick its fine like if i go from 3rd to 4th when i put the clutch in i dont go to fourth just hold clutch the rpms just go to zero and it dies out if i shift normal no problems and the oil light will flicker does the idling have to do with oil pressure???? someone tell me something
Old Sep 9, 2010 | 10:42 PM
cadeMFjohnson's Avatar
Default Re: 90 integra idle problem help me anyone
sounds like your car is probably a wiring nightmare
so it will idle fine.. if you push in the clutch when its idling does it die?
Old Sep 9, 2010 | 10:43 PM
95civej1's Avatar
not kool
Old Sep 10, 2010 | 06:27 AM
idle and i push the clutch in its good its when im shifting and i dont put it in gear in fast enough and let the idle go to 800rpm it just drops and shuts off
Old Sep 10, 2010 | 07:36 AM
collinsvc15's Avatar
I had this same problem awhile back with my hatchback. When it started it would idle fine. But as soon as I let it warm up for awhile it would die when the clutch was pressed. For me it ended up being a vaccuum hose that was connected in the wrong location on my Skunk2 intake manifold & one of the wires to my electric fan was cut, so the car wasn't cooling efficiently. After I switched around some hoses and wired up the fan it ran perfectly. I do not know if this helps you out.
I agree with cadeMFjohnson about the wiring issue. Check out all your wiring for cuts, corrosion, improper grounds, and etc.
skata89
Apr 6, 2007 08:39 AM
NBPdEeCeE
Mar 6, 2007 01:01 AM
hondaracing1
May 15, 2004 09:39 PM
