F22a Axle Question!
I was wondering since i have got a prelude s with an f22a motor and my axles have started to make the infamous ticking noise!
what i wanted to ask you is since it is an f22.. do the 90-93 accord axles and axle parts fit as a replacement? then i mean the u-joint which is my causes the ticking
hoping for quick and good answers
thank you
thank you
well id buy the prelude ones because usually they just reuse the cars axles or do you know if they used the f22? either way pretty sure there the same thing. best thing to do is bring axle with you so the guy can measure it out
and yes of course it's constant velocity, didn't the english term tried a dictionary and failed as it seems..
since the prelude s with the f22 isnt listed in some of their books or something!
It's NOT a swap. He has the USDM 1996 Prelude S model, which came with a f22a. Pretty much the same as 5ga's. His question is valid - Do they share the same axles? I don't think they are. Aftermarket part #'s are not matching, but Honda may have common part #'s for them.
no sir. it is not swapped.
the prelude s comes with the f22 stock. that i know for sure.
the only thing i was wandering about is if the axles as a whole fitted since it is exactly the same motor, f22a as in the 90-93 accord.
since i can get axles from an accord for a few bucks ..
typertn
Jun 27, 2004 05:22 PM
