D16Y7 Stock Header Question
Old Sep 9, 2010 | 08:38 AM
khenning's Avatar
Default D16Y7 Stock Header Question
Can the stock header be separated from the catalytic converter easily? Is it held on with bolts? I have a cracked header and I'm wondering if I need to replace just the top header part or the whole unit.
Old Sep 9, 2010 | 11:04 AM
khenning's Avatar
Default Re: D16Y7 Stock Header Question
bump for an answer?
Old Sep 9, 2010 | 11:19 AM
nub's Avatar
nub
They can't be seperated, one peice unit.
Old Sep 9, 2010 | 11:22 AM
B16AGUY's Avatar
I agree with nub.
Be careful if you replace yourself as there should be an O2 sensor in the cat...make sure not to damage it when you remove the cat/manifold as a new O2 sensor can be a bit expensive depending on what you buy.
Old Sep 9, 2010 | 11:25 AM
khenning's Avatar
Thanks for the answers guys.
Old Sep 9, 2010 | 02:59 PM
canadaek's Avatar
there's 2 02 sensors in the cat
Rotella-t
Honda Civic (2001 - 2005)
May 16, 2008 10:28 PM
ichibano
Mar 15, 2003 04:04 PM
MiamiFlorida
Aug 6, 2002 10:32 AM
solkid
Apr 9, 2002 09:33 AM
