2000 Integra Built, Boosted, Caged :) $10,500
Old Sep 9, 2010 | 08:25 AM
airwalk07143's Avatar
Default 2000 Integra Built, Boosted, Caged :) $10,500
2000 Acura Integra GSR
83,000 Miles
$9,500 obo NEW LOWERED PRICE!!
Please dont lowball.
I prefer to sell this to someone who would take good care of it and enjoy racing it. and not a 16 year old punk.
So apparently life has hit me in the face and forced me to sell my car. My father was in a horrific motorcycle accident and i need to grow up and help him out. Priorities>car. I have had this car for 5 years and have babied it. I built this from the ground up with help of my dad, friends, Leo Troy, and a few others. As the car currently sits, it is 98% complete. I was planning to have it ready for this season but that didn't happen. Currently car is NOT running. It ONLY needs to be tuned (it just got a bigger fuel system in the spring. not touched since.) The motor runs perfect! I also had the 10pt. cage installed this spring and is completed but needs to be ceritfied. It shouldn't be a problem...it was S&W weldin cage with upgraded lower main hoop bar to make it fit current rules. This thing is capable of being a terror in your city. On 20 psi, its the ****ing scariest ride. Car was built to run 35psi or so. Every part on this car will handle it and take a ****ing beating! At 35 psi you should be mid to high 700whp (some have made more). Easily a 9 sec street car! I built the fuel system with E85 in mind but it could be used with any gas.
Engine
Ls/Vtec (under 10,000 miles on build)
83mm benson sleeved block
gsr balanced and micropolished crank
Eagle Rods
83mm CP Pistons 9:1
New oem oil pump, waterpump, timing belt, ect. at time of rebuild
Commetic headgasket
ARP headstuds
SuperTech 0.5mm over sized valve springs
gsr cams
Moroso Oil pan
Edelbrock Intake manifold
Golden Eagle ls/vtec conversion kit
Custom Catch Can setup
Turbo Kit
Peakboost top mount b-series manifold (recently inspected by P.B. Not used since)
Peakboost 3in. downpipe
Peakboost 44mm dumptube
Precision 6765SP Turbo t3(1/2 season use. Never above 20psi)
Precision 46mm Wastegate (Installed in spring. Never seen boost)
Custom 3in. charge pipes
4-ply 3in couplers
T-bolt Clamps
31X12X4 bar and plate intercooler w/ custom single backdoor setup
S.S. oil feed
-10 a.n. Oil return
Fuel System
Sumped Tank (dual -8’s)
Dual Bosch 044’s (1 pump is brand new, other has 1 season use)
-8 an line from tank threw filters, then pumps, the “Y” together to filter and then -10 to fuel rail
STR anodized fuel rail
Bosch 1600cc injectors
Fuel Lab FPR (Brand NEW)
-8 an return line
Electronics
Hondata S300
Boost Solenoid for BBG
Sony Cd Player
Kicker speakers
Additonal Custom Sub encloser, kicker subs, kicker amps are not included but we could work something out. Cheap. (wont fit with the cage though )
Boost Gauge
PLX Wideband O2 (integrated into s300)
Oil pressure gauge (not installed yet)
M&W Pro 10 Ignition (T1 package)
omni 4 bar map sensor
Chassis
2000 Integra gsr Black
Great overall condition with a few minor door dings
Leather GSR seats (comes with rear seats but they wont work with roll cage)
10pt Roll cage (Finshed. Needs to be certified. Shouldn’t be a problem)
17in Buddy Club Wheels
Kumho Tires (good thread)
(2) 24X8X15 slicks with rims
Tokiko Illumina coilover setup
S.S brake lines
EBC Brake pads
Full-Race Traction bars
Avid Motor Mounts (stiff bushings)
Skunk2 Short throw and shift ****
Aluminum Radiator and Fan
Drive Train
C.C Twin disk (used ½ season, mostly street, maybe 15 passes at track)
Stock gsr gearset with OBX LSD (laugh but it works perfect and hasn’t broke!)
Drive Shaft Shop 1000whp axles and hubs (stage 5 old version)
ARP extended wheelstuds
I am sure i am forgetting about some parts...
If you are interested please email me brad.steuer@gmail.com
That is the best way to contact me, since i am not on H-t as much as i used to be.
Last edited by airwalk07143; Sep 19, 2010 at 11:12 AM. Reason: forgot to add injectors
Old Sep 9, 2010 | 08:38 AM
hrs-parker's Avatar
Default Re: 2000 Integra Built, Boosted, Caged :) $10,500
that thing looks beasty..glws
Old Sep 9, 2010 | 12:25 PM
l 92egHatch l's Avatar
brad i got some more pics and some vids of your car at the track. lmk if you want me to post em.
Old Sep 9, 2010 | 07:03 PM
email me whatever you got. Thanks! Sucks i have to get rid of it...
Old Sep 13, 2010 | 12:54 PM
camden's Avatar
sexy bump
Old Sep 18, 2010 | 04:12 PM
Bump. Will go lower on price....
Old Sep 19, 2010 | 11:13 AM
bump
Old Sep 19, 2010 | 05:30 PM
bump
Old Sep 19, 2010 | 10:18 PM
JroseEkb18c's Avatar
sick car. Interested in selling the motor? or keeping it complete?
Old Sep 20, 2010 | 06:07 AM
maxwellmercer's Avatar
Very nice. Glws bud.
airwalk07143
Feb 8, 2011 03:59 PM
airwalk07143
Jan 12, 2011 03:46 PM
airwalk07143
Jan 6, 2011 10:11 AM
airwalk07143
Sep 19, 2010 05:53 PM
jentegraGS-R
Jan 22, 2008 02:46 PM
