h22 all motor need advice
ok so this is the plan so far
h22 type s pistons 11:1 compression stock rods with arp bolts
brian crower stage 3 cams and valvetrain/ head will be cleaned and casting imperfections smoothed/
everything will be portmatched/entire engine will be balance/ i also will be doing a balance shaft removal kit/ skunk2 intake manifold/ aem fuel rail/ skunk2 68 mm tb/ hytech replica header/ mugen exhaust/ stage 2 clutch with a 12lb flywheel/
does this seem like it will be a decent build?
Then throw those cams in the garbage and get a different set. I would recomend nothing bigger than a skunk tuner stage 2 and even that is a big cam for such weinie sucking compression.
J/w if you want, I have a Euro R with PP TB and 440 Saturated RC's I might want to sell. By the way I made 221 whp and 169 TQ on a bone stock h2b, camp 1320 header.
Prob because its way cheaper for the professional product TB and they are pretty much just like a stock TB just bigger with no sticking issues or anything.
Wow I just checked ebay and the skunk2's are running $300...? There is one seller selling the PP for 100 bucks. I say save that $200 for a tune or something else.
To the OP Good luck! post up some #'s when its done. and some pics of the car/setup.
From: Santo Domingo, metropolitana, Dominican Republic
i run a set up like that a few years ago, type s piston with crower stage 3 and Euro R IM, TB 68 Ml, Hytech Header and 3 inch exhaust i make 220 whp and 155 wtq, maybe you got overcame like says 2point6, its something dificult to understaind, since i feel my engine runs very good, later i upgrade to mahle piston dont gain a lot hp , but engine Feels really really fastest than before.
Oh and in rereading the post he actually asked about pump gas.. So i'd say 13.5 is a little high for him. .
Its what i would personally like to run if i was building this.
But then again i wouldnt drive that type of build around every day..
yea them cams are WAY to big for 11.1, i would go lower on cam size and a really good port job and tune. You should be around 240 250 mark. ooooo skunk2 throttle bodys suck!! TRUST ME when ull get one of the flapper screws loose and suck one in and destroy you're engine and have skunk2 say ow well. Ull thank people for sayin go with a professional products.
a properly setup pair of pro2's i do not believe are out of the question. You, of course, will not be getting all the power they can produce but i've seen them do decent on less compression.
jdm knight
Feb 28, 2006 09:06 AM
