d15b7/d16z6 mini me part ideas?
Old Sep 9, 2010 | 06:19 AM
xtreemHonda's Avatar
Default d15b7/d16z6 mini me part ideas?
okay, so I'm building a mini we with the above block and head mentioned. I'm trying to keep it streetable.
But I'm really looking for aftermarket parts too it, I don't wanna just build a majority Honda part motor.
So I'm asking everyone to help me find especially rods and pistons.
And after that I need suggestions for cams, cam gears, valves, valve springs and retainers, intake manifold, bearings, fuel rail, injectors, head gasket, etc.
Idc how expensive the parts are, if I have to save up to have quality I will.
Old Sep 9, 2010 | 07:28 AM
That EF's Avatar
Default Re: d15b7/d16z6 mini me part ideas?
first of all. get ahold of an a6 bottom end. than go from there
Old Sep 9, 2010 | 07:40 AM
BudIce's Avatar
lol... There is nothing wrong with the 1.5 . Actually I like it better for N/A because the engine winds up quicker. Doing a vtec head on it IMO is a waste though. I have seen way too many people have terminal issues with them.
Just my $.02
Do a Multi port swap if not done already , Decent camshaft , Maybe a little head work, Quality header & Exhaust , and be done.
Old Sep 9, 2010 | 08:28 AM
Just my $.02
I'm pretty sure it is already multi port, any ideas for cams, and exhaust and headers?
I really wanna make it as aftermarket as possible, there's a local club with their noses in the air about almost stock Honda's and I wanna show them just epic they can be made. But I wanna use this engine, cuz its hardly ever used.
Old Sep 10, 2010 | 08:03 AM
Anybody else with any advice?
I really wanna mini me it, but I wanna find pistons and rods and bearings and I can't.
Old Sep 10, 2010 | 10:19 AM
wmac's Avatar
its hard to find d15 performance parts(rods, pistons, etc). d16 performance parts(rods, pistons, etc) are cheap and easy to find.
Old Sep 10, 2010 | 10:41 AM
BudIce's Avatar
Actually, ARIAS makes a d15 specific piston line for them. You can also use your stock rods. Just get ARP rod bolts and you will be fine. Stock d15 rods on an N/A setup have been known to get to 200whp before failure. I dont think you will have an issue.
Old Sep 17, 2010 | 05:40 AM
Is there anyway you can point me in the direction of these please?
And I know Eagle has a set of rods.
Does anyone know what the crank is good for?
Old Sep 17, 2010 | 11:18 AM
Okay, so I've changed my mind about the z6 head, I'm just gonna build this motor.
i know that its extra money and such to get it where I want it but oh well, this is how I wanna do it.
But anyways, I'm trying to make sure every part of it is aftermarket, or at least as much as possible.
So I'm wondering if anyone can point me inthe direction of a decent set of aftermarket bearings, valve retainers and springs, a dsitrubitor(sp?), a 130 amp alternator, and fuel injectors.
and also a head gasket.
Now i know more than half of that doesn't need to be replaced but i want to anyway with a aftermarket part even if it doesn't give any benefit over stock, just to say I did.
So even if the injectors are only the same as stock with a pretty name on them then I still want them. Its more of having a motor that I say I completely built than anything else, plus this car is gonna be a semi show car so i want the motor to be pretty.
danielh5656
14
Jul 28, 2011 04:08 PM
Garcia505
Apr 9, 2011 02:36 PM
D15b Sol
Mar 31, 2009 07:14 AM
92_boosted
13
Jul 7, 2007 01:25 PM
