Suspension & Brakes Theory, alignment, spring rates....
My ride quality
Old Sep 9, 2010 | 02:14 AM
ekk41's Avatar
Default My ride quality
Hi. I have a 96 ek that I currently upgrade some of my suspension.
Running
OG omni lca
Asr subframebrace
Ctr rear sway
On skunk2 sleeves with brand new koni yellow shocks
Running 10k/8k spring rates
My konis are adjusted to super soft
My car is not slammed
About 1 1/2- 2 finger gap
On rota slip streams 16s don't know exactly if they are 16x6.5 or 16x7
Have brand new falken ziex ze329 tires
205/40/16
My ride feels really stiff still. Even with my shocks fully soft.
I'm fine with it but my girlfriend I can tell she's not happy that I spent 465 on brand new shocks and only I can feel the difference when she can't really tell.
I was wonder if maybe I installed my konis incorrectly? That could possibly change my ride quality? Anyone know if I should of dropped the car and loosen the bolts to the lca before tightening it? Or is it just because my springs are really stiff and I still feel everything that's on the rode?
Old Sep 9, 2010 | 05:09 AM
kyden's Avatar
Default Re: My ride quality
those are high spring rates, if you wanted something comfortable i would go softer.
Old Sep 9, 2010 | 07:10 AM
neverstop's Avatar
springs are too stiff for a comfortable ride over bumps man and those are also pretty low profile tires.
Old Sep 9, 2010 | 08:09 AM
cruizinmax's Avatar
The springs you are running are the equivalent of 560lb front 450lb rear. You would need something in the neighborhood of 380f 250r to be comfortable. I currently run 380f and 400r on my hatch with konis and its stiffer but not too bad.
Old Sep 9, 2010 | 11:03 AM
TunerN00b's Avatar
Since those tires are smaller in diameter than stock, getting it down to a "1 1/2 - 2 finger gap" is slammed.
The car would have flushed tires if the correct tire size was on the car.
Besides that, adjusting Koni Sports (Yellows) only changes the rebound damping, so no adjustment of them will ever make the car feel softer or stiffer. Adjusting them only changes how the car recovers from a bump. Full soft is probably rather under damped, and would result in a bouncy ride. Comfort would improve on a stiffer setting on the shocks.
Old Sep 9, 2010 | 11:13 AM
nagzz's Avatar
because you uses a coilover sleeves that s why is stiff..
you can change it to 8k/6k rates... i think tein has got this kinds of spring rates..
Old Sep 9, 2010 | 12:36 PM
ekk41's Avatar
Ty all for your guys input. Yeah I mean i was running ona budget with tires and everything else so I skipped out on my sleeves ad reused ones that I had on before. I was gonna go With the gc set up. I'm gonna try to stiffin up my strut first see how that goes. And reason why I got such low profile tires was because I got them for 300 mounted and alignment done and Adjusted my camber. And I think that's a he'll of a price.
Old Sep 9, 2010 | 04:13 PM
cruizinmax's Avatar
Although this is true about the rebound damping it doesn't feel like that on the car. I'm assuming beause it doesn't rebound as fast it is lower in the stroke when the next bump is hit or something.
Old Sep 9, 2010 | 05:05 PM
98civdx's Avatar
Master Detailer
Not totaly true, skunk2 makes 8k 6k in sleves.
Old Sep 9, 2010 | 06:09 PM
VVENOM800TT's Avatar
When you torque the lca bolt (ll 3 of them) the car must bo on the ground so the suspension is under load. If you torqued them in the air then your bushings are binding and your ride will suffer as a result. No other way about it.
You're tires are to small, period. Go to a 205/50/15.
3rd, our spring rates are stiff for street driving. Unless you track the car regularly those are high, by about 2kg/mm front and back.
Fix at least the top 2 and your ride will see much improvement. If you do all three then you're golden.
Last but not least, tell your girlfriend to stfu, its your car, do whatever the **** you want with it.
Old Sep 9, 2010 | 06:15 PM
TunerN00b's Avatar
If you have so much rebound damping that the shock doesn't decompress correctly (quick enough), then the car is over damped, and the ride quality will be rather harsh. (I think that is what is being described in the quoted text.)
On the opposite side, under damped allows the car to "bounce" a few times after a bump, which is also less comfortable. "Feels like an old car with dead shocks" is a good description.
Old Sep 10, 2010 | 12:21 AM
98civdx's Avatar
Master Detailer
That wont end well, ask me how i know.
Btw, hes runing 16's.
The best thing i could say, is if it bothers you look into lower spring rates.
I think it would make a difference in how stiff, but Skunk2 are linar springs which helps in the ride being a bit stiffer.
Old Sep 10, 2010 | 06:22 AM
I guess i'm lucky, my gf is a car nut like me so she doesn't care what do to my car as long as im happy.
Old Sep 10, 2010 | 10:27 AM
cruizinmax's Avatar
Have you ever had the koni yellows?
Old Sep 10, 2010 | 11:16 AM
TunerN00b's Avatar
Yes, paired with GC sleeves and 400/400 rate springs on my 2000 GSR. Why?
Old Sep 13, 2010 | 05:14 PM
cruizinmax's Avatar
Just curious, my shocks don't feel like you described "under damped allows the car to "bounce" a few times after a bump," at any setting. On the softest setting they never bounce a few times. As you turn them up 1/6th of a turn at a time they feel stiffer until the stiffest setting. I do know what an under damped car feels like when I had the same coilovers on the stock shocks. The car seemed to oscillate very badly. I wonder if the difference in weight of our cars has to do with it?
Old Sep 13, 2010 | 05:27 PM
TunerN00b's Avatar
A lighter car needs more shock for the same rate springs. Personal preference comes into play as well.
Full soft, my car doesn't feel under damped to me. However, it does feel better turning them up slightly, which leads me to believe that they must be under damped at full soft. So I just keep turning them up until it feels obviously worse, then back off slightly and call it done. I also end up repeating this procure often, since I keep forgetting to mark the "street setting" before adjusting them for auto-x...
David_ej6
Suspension & Brakes
Mar 20, 2015 04:33 AM
bopbop93030
Suspension & Brakes
23
Jan 22, 2009 07:06 PM
petarr
Suspension & Brakes
Feb 3, 2007 11:19 AM
DCStreetHtch
Oct 3, 2002 07:48 AM
CHONCH
Jul 3, 2002 06:40 PM
