civic rear disc conversion..does it matter what 40/40 prop valve you use?
Old Sep 8, 2010 | 10:24 PM
jxhxb's Avatar
Default civic rear disc conversion..does it matter what 40/40 prop valve you use?
im about to pick up a 97 integra rear disc conversion for my 92 civic..
and everyone is saying to get a 40/40 prop valve..
does it matter what car i get it off of? because i have a DA one thats a 40/40..i know it wont bolt up perfectly but it can work..
just wondering if there would be any difference between that and using one off of a dc2?
thanks
Old Sep 9, 2010 | 06:30 AM
BlueIntegraBoy's Avatar
Default Re: civic rear disc conversion..does it matter what 40/40 prop valve you use?
You don't need the 4040 prop valve with just the rear disc conversion. I ran rear discs without one until I upgraded the fronts to Integra. Pedal pressure and braking were the same prior to upgrading the fronts. But to answer your question, I took mine off a DA. It's the same thing except the mounting bracket is different. It's no big deal since you can still bolt it up.
JDM EJ2
20
Oct 9, 2008 10:00 PM
dj theoretic
May 24, 2008 07:37 PM
98GSR-Turbo
May 16, 2008 02:03 PM
NZDelsoldude
Apr 17, 2006 09:28 AM
