Some White smoke and a little Hesitation....yes i searched.
Old Sep 8, 2010 | 07:33 PM
ek9800's Avatar
Default .
Old Sep 9, 2010 | 04:16 AM
Cynical 1's Avatar
Default Re: Some White smoke and a little Hesitation....yes i searched.
how is the coolant level? white smoke usually equals coolant being burned, which means blown headgasket.
Old Sep 9, 2010 | 04:44 AM
EHondaJDM's Avatar
Perform leakdown test
Old Sep 9, 2010 | 11:23 AM
ek9800's Avatar
Coolant levels are fine, and no signs of oil in the coolant as well.
Old Sep 9, 2010 | 11:29 AM
lunatics209's Avatar
Originally Posted by ek9800
Like the title says, I have an Ls/Vtec with p30 pistons, 310cc injectors, a pretty good build up just had it tuned on crome at churchs made 201whp 157tq.
My concern is sometimes it will blow white smoke out the exhaust when accelerating. Sometimes im crusing and let off the gas pedal and then give it gas again it will hesitate than be good.
No fluids are coming out of the exhaust, oil is not milky compression is 230 all the way across. I'm just looking for some help, any comments would be greatly appreciated thank you.
-Bryan
Wow you made 157 tq on a small 1.8? I find that hard to believe. I guess church's dyno does read high.
Old Sep 12, 2010 | 09:29 AM
EHondaJDM's Avatar
Old Sep 12, 2010 | 09:35 AM
00Red_SiR's Avatar
All Motor Mentor
If your fluid levels arent changing and your spark plugs all look the same (no cylinder looks different from another) I'd say it's just "smoke" and not to worry about it.
tdizz07
Jan 14, 2010 09:04 PM
ELSUICIDA
13
Apr 4, 2007 06:07 PM
EtherEG93
Sep 17, 2005 08:18 PM
Ziggymidget5
May 22, 2005 03:47 PM
t616
Jun 21, 2003 02:35 PM
