Engine wants to stall when A/C is on
Old Sep 8, 2010 | 05:19 PM
titi_vtec's Avatar
Default Engine wants to stall when A/C is on
everytime that i put my A/C it work ok when car is cold, after a 10min runing qhen my car get hot everytime i put it on neutral(manual) my rmp goes down and my car turn off, it does not matter in what speed i am or how fast i go i have to play with the gas to try it stay on, what can be and how can i fix this
Old Sep 8, 2010 | 05:23 PM
Former User's Avatar
Default Re: A/C problem
Does the condenser fan run when the A/C is on?
Any CEL codes?
A good thread title is required and helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
Old Sep 9, 2010 | 07:28 AM
titi_vtec's Avatar
Default Re: Engine wants to stall when A/C is on
yep cpndenser is working ok, and it frezz a lot, and not check engine, this only happen when car ets hot, lol, i am also runing a stock p28 on my stock d16y8, this make some difference?
Old Sep 9, 2010 | 07:33 AM
8VEYBEYB's Avatar
my 98 with a itr swap is doing the same thing , once at operating temp engine will stall with ac on , ac is ice cold and condensor fan works , but it still stalls , I even swapped out IACV's
Old Sep 9, 2010 | 10:04 AM
Clean the IACV and check whether the A/C system is overcharged with refrigerant. Is the condenser clogged with bugs and road debris?
Old Sep 9, 2010 | 11:00 AM
titi_vtec's Avatar
it was working perfect before i swich my tranny from auto to standar, there it star the problem and i have everything correct on my car there is not check engine light, no codes everything work and perfect the a/c is the only one that is making this problem and i test it, and there is not leak, no nothing my a/c is in perfect condition also i have a new compresor in which the problem not end, on old and in new, and everything is working perfect
Old Sep 9, 2010 | 11:27 AM
92egvx's Avatar
good question the same thing happens with my brother integra gsr and my boiz b16 hatch all the same...well hope theres an answer it would be helpful...
Old Sep 9, 2010 | 03:44 PM
When you did the tranny swap, did you properly pin the compressor clutch relay to the ECU?
Old Sep 9, 2010 | 10:06 PM
titi_vtec's Avatar
yes i think so, where can i check that?
Old Sep 10, 2010 | 05:53 AM
Check whether the wire runs to the proper pin of the ECU.
If the compressor clutch relay is not wired to the ECU, the ECU won't raise the idle speed to compensate for the higher engine load from turning the A/C compressor.
Old Sep 10, 2010 | 08:07 AM
titi_vtec's Avatar
mmm... i check everything already and is all connected and ecu is good connected too
Old Sep 10, 2010 | 08:36 AM
If the A/C works and the idle does not increase when it is turned on, then it could be a problem with the ECU or the IACV circuit.
When the engine is warmed up and all electrical is off, does the engine idle up when the high beams, defroster, and vent blower (MAX) are turned on?
Old Sep 10, 2010 | 03:54 PM
titi_vtec's Avatar
not it just work ok in everything work normal, when i put the a/c with all of those thing on it work normal when car get normal temperature start doing the problem again like always
Old Sep 10, 2010 | 04:16 PM
HondacivDX's Avatar
try cleaning the throttle body it might only run better cold because of the fast idle warm up it goes threw
Old Sep 11, 2010 | 04:01 AM
titi_vtec's Avatar
ok i will do that and i let you know what happen thanks
Old Sep 11, 2010 | 05:29 PM
MADeg6si's Avatar
check the compressor to make sure that its running strong.
Old Sep 11, 2010 | 06:34 PM
titi_vtec's Avatar
i clean my intake manifold, throtle body and IACV, and is still doing the same, and my compresor is brand new, with the old one it does and with this one it continue doing it, my dad put my old on his car and work perfect with no problem
dawalace
Honda CR-V & Element
Aug 18, 2017 04:45 AM
higgy1
Dec 3, 2016 01:42 PM
Rooftop-Special
Jun 30, 2010 07:21 PM
Redprelude98
10
Jul 13, 2009 03:41 PM
baphomet
Mar 25, 2005 09:21 AM
