newbie swap help
i got a 97 non vtec accord with a 94 vtec motor useing the 97 wiring harness and ecu i am gettin no spark i am pretty sure it cause it dont have the crank sensor on the 94 vtec motor is in the dizzy i know on a jdm obd1 h22 you can run obd2 on it if you get a h23 dizzy or swap the oil pumps and wire it is it possable to do it with a accord i have never messed with an accord only preludes so any help would be great if i left anything out i am sorry in advance
take your oil pump off the 97 engine and put it on the 94 motor, use your 97 dizzy and the 97 intake manifold. the only problem is you won't have a pin on the ecu to plug in the vtec green and yellow wire since your using a non vtec ecu.
FulRebelArmorer
Oct 1, 2013 01:40 AM
gofastperformance
Mar 25, 2008 04:33 PM
gooberidiot
Sep 4, 2006 01:12 PM
