Transmission & Drivetrain Gearboxes, Differentials, Clutches
What vss to use in cable transmission in a hydro car
Old Sep 8, 2010 | 10:03 AM
sicknastyb17's Avatar
Default What vss to use in cable transmission in a hydro car
I bought a crx that has a b20vtec with a cable s1 trans but the owner before converted the car to obd1 and put a dc gauge cluster in the car. This means the car has a electric vss and not the cable one. The probelm is if you remove the vss and turn by hand or drill the gauge on the cluster works, but if I install the sensor and drive I get NO read from tranny on the gauge or datalogging meaning the speedo gear is not touching the vss gear. I was wanting to know if there is a electric vss to use that will engage the speedo gear in the tranny. Thanks
Old Sep 8, 2010 | 03:36 PM
Default Re: What vss to use in cable transmission in a hydro car
Thanks everybody. I got it. Thanks
Old Jun 12, 2019 | 07:18 AM
Dee9222's Avatar
What did you do to fix it im having the same problem?
Old Jun 16, 2019 | 09:57 AM
Dee9222's Avatar
Can anybody help me with this problem it would be greatly appreciated
RACEPAK
Nov 9, 2023 07:24 AM
dannyb18c
May 11, 2012 02:04 PM
TeamPrestige
Feb 14, 2010 10:16 PM
Turbo Dan
10
May 15, 2008 11:25 PM
rasta420
Aug 26, 2002 04:25 PM
