h23a vtec question?
Old Sep 7, 2010 | 08:44 PM
nicolas1320's Avatar
Default h23a vtec question?
sup guys, i have a 2001 h23a blue top, i made a big mistake in changing the factory intake manifold the engine brought to the us one. both look the same but there not the same.the gaskets don't match, and the injectors don't work properly with the us manifold, please were can i get this gasket.
Old Sep 8, 2010 | 07:54 AM
F20B_accord's Avatar
Default Re: h23a vtec question?
so ur looking for an h23 im gasket? you can use a h22 one and h22 injectors
Old Sep 8, 2010 | 03:47 PM
yea i know, iwanted to go back to the jdm manifold but just found out that the problem now is the injectors im using, sense i could not use the h23a injectors i poped in the ex accord injectors from the f22 engine my accord had,and guess what? now im running lean,crap crap crap. i put on a air and fuel gauge and that thing don't go to rich even if it wanted too.
Old Sep 9, 2010 | 07:40 PM
i just orderd the injectors from a h22a1 hope this evens out the problem
Old Sep 9, 2010 | 07:52 PM
GhostAccord's Avatar
Why is it that you can't use the H23A injectors? I bet they are larger than the ones you ordered for the H22A1.
Old Sep 9, 2010 | 08:10 PM
the thing is that i had changed the intake manifold to the us one and at the same time put in the hondata gasket, but it dind't work with the h23 injectors because they need air,the us manifold is not compatible with the h23 manifold, it has a air hole in each injector port and the us don't have this holes so the engine gets flooded with gas.
Old Sep 9, 2010 | 08:14 PM
right now im running it with the f22 vtec injectors and it sucks.
Old Sep 9, 2010 | 08:51 PM
That is called the Fuel Injection Air Control System (FIA), the 94-95 F22B1 has those holes. As well as one of the F23s. All you need to do is plug the holes feeding the injector with a bit of silicon/JB weld.
Are the H23 injectors low or high impedance?
The F22B1 injectors are only 240cc low impedance, I bet those H23 VTEC injectors are 345cc high impedance.
Old Sep 10, 2010 | 03:36 PM
well the thing is that if i seal those holes the injectors send more gas, i put those injectors in the us manifold, i put a full tank of gas on friday and by monday it was empty lol, so i put on the accord injectors for now.
Old Sep 10, 2010 | 04:25 PM
What ECU are you currently running?
The H23 injectors shouldn't inject more fuel if you block off the FIA. If your O2 sensor is working properly it will keep your AFRs in the proper range. It shouldn't add more fuel for no reason.
As for your fuel mileage, I'm pretty sure that's what happens when you drive an 2.3L DOHC VTEC with 290cc-345cc injectors without a proper tune. You shouldn't be swapping injectors back and forth without making sure they are the proper impedance and flow rate for the engine and engine management.
Old Sep 10, 2010 | 05:25 PM
well i thought that if the injectors don't have that air feed they will dump more gas, and about the ecu i have a p28 with prelude basemaps. the car was running fine with the ecu,all this started happening when i switch the intake manifolds. if i was to find the same gasket from factory that bellongs to that motor trust me i'll put everything back to factory.
Old Sep 10, 2010 | 05:37 PM
you know i was looking at the intakemanifold gasket from a 98 f23 and it almost looks the same but im going to take the manifold and se if they match?
Old Sep 10, 2010 | 07:07 PM
Yup......The 98 Accord EX 4dr has the FIA.
The 94-95 Ex F22B1 also has those holes as well. I'm pretty sure they are the same pattern.
Sorry reading owns me. I thought you were looking to get rid of the FIA. Just looked at your original post and you are looking for a replacement gasket..... Sorry about the big run around.
Old Sep 11, 2010 | 12:19 PM
no need to appologize just miss understood but when i did the swap i tryed to put the f22 intake manifold on and did not fit,is thef22b1 diferent from the f22 vtec?
Old Sep 11, 2010 | 01:37 PM
No they are the same layout. The only difference between the B1 & B2 are the FIA holes.
The H23 VTEC head must be the same design as the H22 head. You may have to take an H22 gasket and cut/drill the FIA holes in it......
Old Sep 11, 2010 | 05:38 PM
But that's if I use the factory gasket because right now I have the plastic one they use for racing and the problem with that one is that the shape that it has is just to cover the head inserts. That's y I can't put back the stock manifold. If u see the gasket pix u showed me and comepare it with a h22 gasket u will see what I'm talking about.
Old Sep 11, 2010 | 05:40 PM
This engines Are very complicated if u ask me lol
Old Sep 20, 2010 | 01:14 PM
well over the weekend i bought the 98 accord f23 intake gasket and it does not match. the h23a one is a lot bigger.
Old Sep 20, 2010 | 01:17 PM
i wish i new somebody in europe,they can realy help me with this engine sence its imported over there. they should know what part i need. lol
Old Sep 21, 2010 | 03:44 PM
well i bought some gasket paper,i guess i'll have to make the factory gasket to use the injectors and the factory manifold.question,is the h22a4 injectors the same as the h22a1 injectors or the h22a injectors?
Old Sep 21, 2010 | 06:58 PM
Nope! The H22A4 injectors are 290cc high impedance and the H22A/A1 are 345cc low impedance.
Old Sep 22, 2010 | 03:41 PM
ok thanks I knew there was something rong,any way almost done with the stock gasket,ill see if it pulls good.can a tune p28 get the program eraced by taking it off alot or something, or by receting it alot?because im thinking on re-tunning it.
Old Sep 22, 2010 | 08:08 PM
Stranger things have happened with chipped ECU's however, if it was erased it probably wouldn't work and it would throw a CEL. Personally I have never had any issues with ECU's loosing a tune (knocks on wood!) I have had ECU's pulled in and out numerous times, thrown around and dropped still keep a tune.
What software are you using?
Old Sep 23, 2010 | 02:29 PM
ok man thanks a lot,well i put the intake manifold today and it feels alot better than the us intake manifold. to all those people out there dont ever change the intake manifold on a h23a vtec engine, u dont need more than that i asure u.
Old Sep 25, 2010 | 01:45 AM
suzukiookie's Avatar
HONDA PRELUDE
(JIS part # HHSH23) is for:
92-96 Prelude, H23A1
2.3L, DOHC, L4, 16Valves
contains multi-layered metal head gasket, intake manifold gasket, exhaust manifold
gasket, valve cover gasket, viton valve stem seals, camshaft seal and other gaskets. Injector seals are not included
just what you need call the at 18884824734
or just buy on ebay item number 130322894458
and i dont know why you got a blue top the factory says this they all black top
H23 series
i just got a h motor myself that im going to put in 92 96 Honda Prelude Accord Engine Swap JDM H22A OBD-1
ENGINE + 5-SPEED TRANNY + ECU + SHIFTER CABLE+DOWN PIPE i paid 1400 on ebay but i want to get a turbo kit and that hondata before it goes in do you live in pa you check it out my last car was a jetta with sds stand alone engine management t3/t4 garrett turbo stright pipe exhaust supercharger cam i put 11000 into the car then a tree fell on it wtf but i raced some kid with a turbo vtec and he ate me up so i will do a honda up to the max i just rebuilt my f22b1 motor just cause im retarted i just got so much to do but love working on cars well enough blabla bla i hope that link and phone number helps you if not i know another place you can get it from
The H23 was an increased-stroke, non-VTEC version of the H22, used in Japan, North America, and Europe. It shared the same Fiber Reinforced Metal (FRM) cylinder wall liners with the H22.
Specifications
* Bore × Stroke: 87.0 × 95.0 mm (3.43 × 3.74 in)
* Displacement: 2,258 cc (137.8 cu in)
* Valve Configuration: DOHC, 16 valves
* Type: In-line 4 cylinder, aluminum block and head
* Compression ratio: 9.8:1
* Max power: 170 hp (127 kW; 170 hp)
* Max torque: 156 ft·lbf (212 N·m)
* Redline: 6500 rpm
* Engine Control System: Honda Systems PGM-FI with port fuel injection
* Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
H23A
* Found in the Japanese 1992-1996 Ascot Innova 2.3Si-Z (2WS CC4 & 4WS CC5). It produces 165 PS (121 kW; 163 hp) & 156 ft·lbf (212 N·m) and comes with a "black top".
H23A1
* Found in the American 4th gen Prelude Si (BB2). It produces 162 PS (119 kW; 160 hp) & 156 ft·lbf (212 N·m) and comes with a "black top".
* Found in the American 1995 Prelude SE (BB2). It produces 162 PS (119 kW; 160 hp) & 156 ft·lbf (212 N·m) and comes with a "black top".
* Found in the Canadian 4th gen Prelude SR (BB2). It produces 162 PS (119 kW; 160 hp) & 156 ft·lbf (212 N·m) and comes with a "black top".
* Found in the Australian 4th gen Prelude Si (BB2). It produces 160 PS (118 kW; 158 hp) & 156 ft·lbf (212 N·m) and comes with a "black top".
* Found in the Australian 1991-1993 Prelude SRS (BB2). It produces 160 PS (118 kW; 158 hp) & 156 ft·lbf (212 N·m) and comes with a "black top".
H23A2
* Found in the European 4th gen Prelude 2.3i (BB2). It produces 160 PS (118 kW; 158 hp) & 154 ft·lbf (209 N·m) and comes with a "black top".
H23A3
* Found in the European 1993-1995 Accord 2.3i SR (CC7). It produces 158 PS (116 kW; 156 hp) & 154 ft·lbf (209 N·m) and comes with a "black top".
* Found in the European 1992-1996 Rover 623 SLi, GSi, and iS. It produces 158 PS (116 kW; 156 hp) & 154 ft·lbf (209 N·m) and comes with a "black top".
H23A VTEC
In 1998 Honda produced a rare VTEC version of the H23 engine for use in Japan only. It is essentially an H23 block with an H22 head. The power is on par with a typical H22 engine but with a lower redline.
* Found in the Japanese 1998-2002 Accord Wagon SiR (CH9). It produces 200 PS (147 kW; 197 hp) & 163 ft·lbf (221 N·m) and comes with a "blue top".
* Found in the Japanese 1998-2002 Accord Wagon AWD (CL2). It produces 200 PS (147 kW; 197 hp) & 163 ft·lbf (221 N·m) and comes with a "blue top".
i just listed these to make sure one of these have the gasket you are looking for well sorry for all the bullshit
