whats biggest tire size you can put on type s with stock wheels
Old Sep 18, 2002 | 09:41 AM
gsrapper's Avatar
New User
Default whats biggest tire size you can put on type s with stock wheels
i was thinking 215/55 16 but could you go bigger on stock rims i just want as much contact with the road as i can have and have that nice fat look on my tires not the little donut of a tire the s has. On my integra i had 205/55's that **** looked great i would like the same look on my s
Old Sep 18, 2002 | 04:11 PM
gsrapper's Avatar
New User
Default Re: whats biggest tire size you can put on type s with stock wheels (gsrapper)
anybody????????????????
Old Sep 19, 2002 | 10:19 PM
gsrapper's Avatar
New User
ANYBODY?????????????????????????????!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 20, 2002 | 12:16 AM
j.honda's Avatar
you could go with a 215/55 16 but a 225/50 16 would be a better choice and probably handles better. the 225/50 16 is also probably the widest you can go with out having too much roll over on the sidewall. the stock size 205/55 16 has an over all diameter of 24.8 inches and so does the 225/50 16. the over all diameter of the 215/55 16 is 25.2. that's almost one inch taller than your stock. there may be rubbing. toyo tires carries this size in the proxes fz4, proxes t1-s and nitto tires nt450, nt555, and nt555r. i'm sure other tire manufactures have these sizes as well if you do not want to go with these. hope this helps, let me know what route you take.
Old Sep 20, 2002 | 08:55 AM
gsrapper's Avatar
New User
Default Re: whats biggest tire size you can put on type s with stock wheels (j.honda)
so 225/50 16 would be the best size width wise and no rubbing problems. I will probably get these tires around december i will most likely get the kuhmos but if have some more money get the the bridgestones potenzas. thanks man
Old Sep 20, 2002 | 12:13 PM
DC5-R's Avatar
I heard the Dunlop FM901s are good as well as the Bridgestone RE711 also heard good things about the Azenis...
Old Sep 20, 2002 | 01:47 PM
j.honda's Avatar
keep me posted on what you decide to do. hope all goes well.
Old Sep 22, 2002 | 08:56 AM
blackrsx's Avatar
i have 225/50/16, with sum cheap Kumho 712's...mmm oversized tires
Old Sep 22, 2002 | 01:28 PM
uNF$@#!'s Avatar
Default Re: whats biggest tire size you can put on type s with stock wheels (blackrsx)
the misinformation shared in this forum is sometimes funny to watch....almost enticing enough to keep quiet and let darwin take his theory to work.
225s will rub for sure on the stock rims.
Old Sep 22, 2002 | 06:28 PM
j.honda's Avatar
Default Re: whats biggest tire size you can put on type s with stock wheels (Soup ****)
have you had first hand experience with the 225's rubbing? or are you just guessing? I have had 235's on my car with a 2.25 inch drop with out any rubbing even with hard corning and without any fender work. i'm not doubting your opinion but out of my own experience and knowledge of tires (given that i am an employee of a tire manufacturer) i dont see why the 225's would rub. if they do, then i am at fault and i apologize in advance for giving misleading info. but again, i have had 235/45 17 on a 17x9 rim with no rubbing or any problems and i do know some stuff about tires and sizing.
Old Sep 23, 2002 | 01:39 PM
rsxylady's Avatar
how do you know for sure they'll rub??
I have 225/50/16 on my stockies and they ain't rubbin.
had them on for at least 4 months now.
I'm using them for daily driving as well as autox and haven't had any problems with it. Also, a bunch of my rsx friends are using the same tire size and they haven't had a problem either.
[Modified by rsxylady, 10:42 PM 9/23/2002]
Eihctab
Honda Civic (2001 - 2005)
Mar 26, 2010 06:17 AM
DIYaccord
Feb 6, 2005 10:19 AM
2000gsrsedan
Mar 28, 2003 05:18 AM
2000_Civic_Si
Mar 26, 2002 04:31 PM
HondaIntegraLS
Jun 27, 2001 07:43 PM
