FS 2k fully bulit race lsvtec port/polish+stage 2 cams and more built by alaniz shop
Old Sep 7, 2010 | 04:34 PM
Eviltek1989's Avatar
Default FS 2k fully bulit race lsvtec port/polish+stage 2 cams and more built by alaniz shop
im selling a fully built race b18a with a b16a head .motor has 1500 miles just to break in just to make sure it didnt leak or smoke... and it doesnt everything flowes right no leaks no smoke idle is perfect on right tune.
ls b18a block
build from alaniz dfr race shop in california
91 Ls Block
Bored .5 over
New 81.5mm ACR high compresion full race pistons
Pistons Diped n a protective coating to make them stronger will withstand high heat and rpm
New arp head studs
New new comet 3 layer head gasket
New golden eagle dowel pins
New gaskets from top to bottom
New 4-1 race headers
New 2 1/2 inch full race catback exhaust
New Nitric pistons rings
New ARP rod bolts..
New ls rods shotpeend
New Race bearings
Micropolished n balanced crankshaft
New Kings thrust Full Race Bearings
New main seal
p75 obd1 tuned and chipped ecu
redline 8500rpms/vtech hits at 4000 rpms
obd2 wireing harness
new performance lightend pully
All seals are brand new block was decked and cleaned before the build block was shaved for higher compression
2000 b16a full race head
built by alaniz dfr race shop in california
full race all angles port and polish also has coating over polish for flow test...flow test was real good by the way
all new seals and pins
new supertech valve guides
new supertech flat vaves
new supertech retainers
new supertech spring... very strong
supertech everythng no oem in it....
toda spec bs stage 2 cams
intake side bored .5 oversized for more air flow
walls where shaved down for better flow and low temps...
head was also polished and cleaned
new b16 dizzy
str high voume fuel rail
costum injector clips
b16 intake manifold
this is all motor 12 sec set up fully built theres been alot of time and money into this looking to sell it for a good price already tuned and chiped looking for some money or a nice boost built set up or nice turbo setup trade open for offer but money is king serious buyer only email T04Bturbo@hotmail.com will respond asap. 775-229-6486 ask for jose or pm me
Old Sep 9, 2010 | 01:59 AM
hollywood96ex's Avatar
Default Re: FS 2k fully bulit race lsvtec port/polish+stage 2 cams and more built by alaniz s
whats the price
Old Sep 10, 2010 | 11:30 AM
im looking for a best offer or some type of good trade like boost wise or supercharger wise
Old Sep 10, 2010 | 11:32 AM
98integrars's Avatar
so your trying to get out of the scene yet you want a turbo/supercharger? sketchy!
glws
Old Sep 10, 2010 | 12:13 PM
oops that was a copy and past from a month ago when i found out i was having a kid now im kinda more comftrable and just looking for a offer or cash im an addict to the honda scene
Eviltek1989
Jun 29, 2010 03:46 AM
Eviltek1989
13
Jan 22, 2010 04:24 PM
