help!! smog code p1336 #54 acura integra
Old Sep 7, 2010 | 12:11 PM
replicaITR417's Avatar
Default help!! smog code p1336 #54 acura integra
i'm running jdm 96itr obd2 into 96obd2 integra chasis. I got my car smogged today and i failed with code 54 CKF. before going in to smog, I did the CKF bypass trick, reset ecu and check engine light was not present. during the test the check engine light came on. did I wire this wrong?
I did C1 splice into C4, cut off the harness end/not the ecu end.
I did C11 splice into C14, cut off the harness end/ not the ecu end.
I disconnected the CKF sensor( I have the sensor but it is not mounted in the oil pump/crank), so the plug is just flying around.
does anyone know if i did something wrong? I test drove it after I did the trick, rev it high, smashed, no check engine light but suddendly it showed up at the smog station
vega_ROCKS
Jun 25, 2005 01:12 AM
redlinegsr
Jul 22, 2003 01:40 PM
andrew dc
Aug 18, 2001 03:40 AM
