B*tch Pin
I'm having a lot of problems removing the bitch pin from a b-series tranny. I've tried using a bunch of different sizes of punches and even drilling it out. Any tips or tricks would be appreciated.
Thanks
EDIT: or is there any way to remove the shaft that the linkage connects to?
Thanks
Well, usually, the punches just go in and spread the clip, which is what you don't want. A 6mm thin-wall socket works pretty good. Since you tried drilling it out, chances are there isn't much you'll be able to do now. But I don't know how bad it is.
If you have access to an air supply, get an air hammer with a pointed insert and go to town.
The shaft will slide out, but it requires disassembling the transmission, IIRC. Haven't pulled that out in a while to remember exactly how it connects.
seriously? I could sell a million of these. anyone that works on their honda needs one!! takes about 5-10 seconds and its cheap! I look foward to using it.
http://sptool.com/index.php?page=sho...mart&Itemid=11
^ well thats a fancy lookin punch u g0t dere.
oh yeah op, 7.9 or 8mm punch is the way to go. just keep hitting it. (billy mays key) I THOUGHT MINE WAS STUCK AND I WAS DOOMED, BUT I JUST RAISED MY CAR A BIT MORE AND HAMMERED IT OUT. (end billy mays RIP) took about a total of 3 hrs, 20 min of actual pounding. the other 160min were spent saying "fuuu i wish had a air hammer" or "let me bust out my iphone and google B!tch pin removal" or eating, or walking the dog.
good luck.
good luck.
Air chisel with the pointed tip gets them out in literally 1 second. Place tip on bitch pin and apply pressure, pull the trigger and out shoots the bitch pin.
Get a cheap one at harbor freight or something.
I used to beat the hell out of them with a punch till I bought an air chisel for another project and tried it on the bitch pin.
you can unhook it from the shifter and pull the linkage out with the transmission. Then it is easier to work with out side of the car. once you get that **** out put a bolt in it so you don't have to deal with it again.
Or an ac bolt that holds the bracket on. Those have worked the best for me.
Some people use the c-clamp, socket and bit method but I never have any luck with it.
Since ive used a a/c compressor bolt and 5 lb hammer ive never had 1 bitch pin take over 20 seconds to remove. I used to use a lighter hammer and a punch but had horrible trouble. The trick is getting it high enough off the ground with the right size bolt/punch so you have room to swing a heavier hammer. Just dont miss :\
I got the pin out a few days ago and I haven't messed with it much since. I am having difficulties getting the linkage disconnected from the transmission though. I've tried hitting it with a hammer a few times and I'm scared I'm going to do damage to the transmission (it's out of the car by the way). hi While drilling out the pin I didn't do any damage to the shift linkage or transmission, I do need to buy a new pin though lol. I've been spraying PB sray where the pin goes in periodically, hopefully it'll come off soon.
you can use one of the two bolts that holds up the shiftlinkage to the body, that's always worked great for me. i'm 120 lbs with not much muscle and i get it out quite easily
You can't get the car high enough off the ground to swing a hammer if you're using jack stands. So what I do is just drop the whole shifter.
Maybe I'll get an air hammer next year when I have to pull my GSR trans, but I'm not even sure it will be short enough to work with jack stands.
ACURA/HONDA AIR HAMR LINK TOOL
* Use an air hammer for quick service of shift pin.
* Includes a guide step for precise removal and repair of shift linkage pin.
* Works on: HONDA Civic 1986-2002, CRX 1984-1991 ACURA Integra 1987-2001
Part#: MST6565 Price: $29.35
