problem with car starting
Old Sep 6, 2010 | 02:32 PM
ddeem1's Avatar
Default problem with car starting
I have set the timing on my 96 honda accord F22- All the marks are lined up on the timing and the interference belt. It runs great if I switch the plug wires from 1-4 2-3. If I connect the wires the correct way on the cap then it will not start. When it runs the oil pump is working and the engine sounds great. Why is it running this way and can it harm the engine ?
Old Sep 7, 2010 | 07:23 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: problem with car starting
maybe what you think is wrong is really correct and what you think is correct is really wrong? it's just a thought since I'm not clear on how you have the wires connected.
Could you be more specific on how you have the wires connected at the spark plugs and how you have them connected at the distributor cap? Maybe a picture would be easier?
Old Sep 7, 2010 | 08:04 AM
chikin pickle's Avatar
See what direction your distributor rotor is facing. It could be you need to reverse the rotor.
Old Sep 7, 2010 | 10:09 PM
holmesnmanny's Avatar
Looking at the cap from the passenger side of the car, one plug wire down clockwise from the line thing on the cap, it's 1-3-4-2 in that order.
Old Sep 13, 2010 | 03:35 PM
ddeem1's Avatar
Is this picture correct. I have checked the timing marks and everything is good.
http://autorepair.about.com/library/a/1f/bl269f.htm
Old Sep 13, 2010 | 04:06 PM
redbull-1's Avatar
Agreed. A picture of your car wiring could solved this for sure. However, see the attached picture for how the distributor cap wiring looks like for F22B1 and non-F22B1. Note the difference in the shape of the cap and the No. 1 cylinder mark on the cap.
mikesp0008
Apr 17, 2018 02:54 PM
`chrisb
Apr 29, 2008 08:31 PM
integ_lude
10
Oct 1, 2007 04:02 AM
krazyteg
Apr 11, 2006 02:55 PM
93H22Lude
Oct 13, 2005 01:22 PM
