Need your opinion 99 civic si ls vtec
Old Sep 6, 2010 | 07:10 PM
1off's Avatar
Default Need your opinion 99 civic si ls vtec
So here's the build half way done block is ls stock 81 mm eagle crank and h beam rods je 12:1 compression pistons clevitte 77 h series bearings arp bolts head is port polished skunk2 everything springs retainers and pro series stage one cams oh and high compression valves gates timing belt vtec kit obd 1 conversion harness and ecu unorthodox pulleys water pump oil pump 550 cc injectors fuel pump upper intake manifold venom 62 mm bbl throttle body and arm cold air intake and 2 1/2 inch exhaust what do you think horspower wise and if you see anything I'm missing will greatly appreciate it question will hondata s100 chip b ok or chrome? Question can I use l/s motor mounts and will new oem water and oil pumps b kool thanks guys for your insight
JENNY_EG6
Sep 2, 2010 08:48 AM
94WhtTeg
10
Jul 10, 2008 06:37 PM
Wopsicle69
Jan 26, 2005 07:01 PM
