Cleaning your engine...
Just wanted to know what youve used in the past or currently use to keep your engine and transmission clean.
Ive used diluted acid and a heated pressure washer but is there anything else that you've had success with? thanks
If you have any before/after pics it would be appreciated.
just depends on the amount of grime...
my car, since it's an '08, i can use optimum power clean at 10:1, a boars hair brush for crevices and water spray bottle to wash it away in a controlled manner so i don't have to cover anything.
i've used optimum power clean at full strength, agitate with a medium to stiff bristle brush, and spray away with the water.
i've used gunk engine foam (the stinky stuff) and a water spray bottle to rinse it off.
i've seen people use steam and a brush.
your technique is probably just fine if it has worked before and as long as you are covering sensitive electrical/electronic stuff, using a acid ratio that isn't too strong and aren't getting the pressure washer too close to anything.
i like to use optimum tire shine for most rubber and plastic, etc. under the hood, since it's water based and actually feeds the rubber. for quickies meguiars hyper dressing at 3:1 or 4:1 is awesome too...it's also my go to for fender liners/wheel wells. stuff is awesome and also water-based.
I going to try some of the stuff you guys use thanks.
I have a B16A in the 98 Civic coupe. They are notorious for the cam plug leaking oil and Ive gotten that fixed. I cleaned up the transmission but the block has alot of grime. What would you use for that? thx
Brake Cleaner
has been tried by just about everyone. Im not a noob, just want to try something new thats efficient. How many cans would it take to clean an entire engine? Too many in my opinion.
go to the carwash, use there engine/tire cleaner and then use the high pressure rinse. works really well! u just gotta cover up a few things such as dizzy, air cleaner, and the spark plug wires
Ive used orange degreaser before. It works well.
Thanks killahatch, Ive tried that before it did work pretty good.
Im going to take a picture of my motor its on a stand now so itll be easier to clean while im taking care of a few things on it before I transplant it into my car. The dirt on here is just caked up on it. I guess a toothbrush would be good with all your ideas if I kept it clean all the time.
What about that first clean though with mud/grime/grease caked on it. Do you really want to be there all day with a toothbrush? Not trying to say its not a good idea cause it is. What about alot of dirt?
cleaned
painted
are you serious? there is no problem with your cooling from painting an engine block.. whether you like it or not is your opinion, but I figure it looked better than beat up old block..
All im saying is you cant argue the fact a painted block will hold in more heat then a bare block. thats all i was trying to say. more heat=more wear and tear.
