How to pull interior panels?
Old Sep 6, 2010 | 06:02 PM
millertime1388's Avatar
Icon2 How to pull interior panels?
Looking to run my stereo in my 1999 civix dx hatch... Wanting to do it right for once so im looking how to remove the rear side panels. Does anyone know of a good do it yourself posting or a have good discriptions on how to pull it out right with out breaking all the pop rivits?
Old Sep 6, 2010 | 06:09 PM
EJeff8's Avatar
Default Re: How to pull interior panels?
Just give them good tugs, Idk what you mean by rivets, they're all in by cheap plastic clips
Also, why do you need the rear ones out for your stereo?
Old Sep 6, 2010 | 06:31 PM
Running the wires down the sides for the sub and amp.. Ya the plast clips are what i was talking about but for some reason it felt like there was more than just the plastic clips.
Old Sep 6, 2010 | 06:35 PM
EJeff8's Avatar
No, the panels just have clips over the body metal and other overlapping panels and plastic clips, if they break, AZ sells them cheap. Just give good but quick pulls and you'll be fine. Also, just fold your seat down and shove it from the back seat, under maybe a slight portion of the rear side panel and then the runner, rather than just pulling that whole panel off, you can just lift the bottom a little bit and push the wire through.
Old Sep 6, 2010 | 10:42 PM
thumper64's Avatar
The only part you have to pull up is that panel that goes in the door opening. That you just pry up. Otherwise the carpet pulls back and just run it to the back between the seat and trim.
Old Sep 6, 2010 | 11:26 PM
98civdx's Avatar
Master Detailer
Youll have to pull your seats. And then give them a good tug.
The clips are only plastic you might and most likely will break them. It isnt a big deal shucks sells them cheep.
Old Sep 8, 2010 | 04:34 PM
Got it figured out and ran thanks guys
cadeMFjohnson
Jan 2, 2009 09:27 PM
'95 BA8
Dec 25, 2007 06:39 AM
dalam
Nov 3, 2004 12:35 PM
raybord
Aug 7, 2004 03:06 AM
lke2drvgsr
Jan 8, 2004 02:10 PM
