92' civic hatchback - Amber Corners installation
lololololololololololololololol
1. pop hood
2.unlatch hood
3.open hood
4.prop hood open
5.grab phillips head screwdriver
6.make sure you're holding screwdriver properly
7.look at corner light
8.see the screw just inside the fender, above the corner light
9.unscrew that very same screw you've found
10.hold screw in opposite hand
I'll finish my write up tomorrow I've got class in the morning! thanks to everyone!
But are you serious about this?
EDIT: I'll feel like an ******* if you're seriously having problems with this...
1. pop hood
2.unlatch hood
3.open hood
4.prop hood open
1. pop hood
2.unlatch hood
3.open hood
4.prop hood open
1. pop hood
2.unlatch hood
3.open hood
4.prop hood open
1. pop hood
2.unlatch hood
3.open hood
4.prop hood open
1. pop hood
2.unlatch hood
3.open hood
4.prop hood open
1. pop hood
2.unlatch hood
3.open hood
4.prop hood open
1. pop hood
2.unlatch hood
3.open hood
4.prop hood open
Dont get mad this whole site is full of this
Who can forget this one?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/benen-tow-hooks-2821212/
Well, there are two little prongs that guide the light in...be careful not to break them. Also make sure the corner slides in on its track. And unplug the bulb behind the corner lamp when pulling it. Seriously.
fm
fm
It's just because it's easier than changing oil or a tire... It's easier than changing a headlight and just as easy to find. But hopefully the actual help some of us have told you helped out.. I'm going to go out on a limb and say you're a super noob and never really did ANYTHING on a vehicle??
ef9robert
Aug 2, 2005 07:57 PM
