b18b1 wont run right!?
i swaped my 95 civ to a b18b1.. to get it to start you have to hold it at WOT, it will idle very ruff, and wont rev if you are giving it gas.... the motor is out of a 98 teg.. but im running an obd1 ls ecu. i used the stock civic wire harness. what could be my problem? also the timing is right on..
i found out it is not getting enough fuel.... if i tun the key on and off a bunch of times befor i start it, it somtimes will start and run normal for a few seconds... so befor i change the pump, why would it run fine with the d series in it but not with the b? are the pumps that much diffrent?
ill check the ground. but there is hardly any fuel in the rail... i just find it funny that this problem started after i put the new motor in... in going to change the filter and see what happens
Was the original MAP sensor for your 95 Civic mounted on the firewall? If so, is the MAP sensor connector plugged into the old MAP sensor or into the one on the throttle body?
Can you post pictures of the cam and crank positioned at TDC1?
