Do i need a manual Y8 intake manifold when converting to 5 speed?
Old Sep 5, 2010 | 11:08 PM
JHP's Avatar
JHP
Icon6 Do i need a manual Y8 intake manifold when converting to 5 speed?
Im collecting parts to convert my auto 98 civic ex to 5 speed. After reading the faqs on this swap im not really sure if I need a manual Y8 manifold. I understand that I will have to get a manual throttle body but im not sure if I need the intake manifold. If I do need it, why? Is there anyway that I would be able to get the auto one to work? Or can I just keep using the one I have?
Old Sep 6, 2010 | 02:57 AM
94EG8's Avatar
Seagull Management
Default Re: Do i need a manual Y8 intake manifold when converting to 5 speed?
At the very least you will have to drill out the mounting holes for the IACV as get a manual IACV. Its easier to just get a 5 speed IM though (try to get one from a '96 - '98, '99 - '00 are a little different)
Old Sep 7, 2010 | 05:32 PM
JHP's Avatar
JHP
^ Thanks. I picked up a manual manifold. It should be good to go once i add an IACV and swap the injectors and fuel rail and everything else over, correct?
Old Sep 7, 2010 | 06:12 PM
94EG8's Avatar
Seagull Management
Correct.
Nov 4, 2012 07:24 PM
93eg2james
Aug 25, 2006 03:51 PM
dw.VTEC
Apr 8, 2005 03:59 PM
cyberx
Apr 1, 2003 04:01 PM
crx(gator)
Mar 26, 2003 09:19 PM
