T3 50 trim Vitara build d16z6 dyno results
Engine
d16z6
vitara pistons
FJ h beam rods
Turbo set up
T3 50 trim
0.9bar wastegate spring
front mount intercooler
tuned on eCtune
I was expecting the turbo would spool a lot quicker than it does..
any idea why the turbo would spool so slow?
http://img20.imageshack.us/f/copyof9...ynoseptem.jpg/
d16z6
vitara pistons
FJ h beam rods
Turbo set up
T3 50 trim
tuned on eCtune
Do you have a picture of your turbo?
Id like to see how big it is compared to mine, Im not familiar with this 50 trim a/r .48 stuff. I have a similar motor setup as you though.
check for boost leaks, or at least leaks between the motor and the turbine housing.
although it comes on a little late, your motor did make good power
I had a very restrictive exhaust on the car.
to make a long story short, I thought it was a 2.5" inch. but at one place it was as small as 1.75 and at the axle it was 2.25..
