Parting-Out TURBO DA
Complete Custom Turbo kit made to fit a 90-93 Integra.
GT2871R Turbo
Edelbrock Turbo Manifold
Custom Charge Piping (Heat Wrapped)
Greddy Type-S BOV
Precision 450cc injetors
3" Spoolin DP
EARLS Fittings
3BAR GM MAP Sensor
Hallman PRO MBC
Greddy FMIC
$1800 FOR A COMPLETE TURBO KIT.
$2050 WITH HONDATA installed on a RARE P61 ECU made 270/180@9PSI ($275 separate)
$2250 WITH ABOVE + Innovatie Traction Bar ($225 separate)
Innovative Steel Mounts for a 90-91. $180
Koni yellows + H&R Race Springs. $500 NO MORE THAN 10K
5Zigen FN01Rc Wheels with BRAND NEW Falken ZIEX 205-45-16 Tires. - $650
Spoon Lug Nuts - $100
Spoon Titanium Shift **** - $80
Neuspeed Strut Bar. - $100
B16A Cable Transmission. GRINDS 3RD Gear. $275
Action Clutch Stage 2 for small spline cable trans. $180
10lbs Flywheel. $120
Or buy complete drivetrain for $550
B16A2 Head. ITR Valvetrain. P&P and rebuilt by CTR Dynospot in MODESTO, CA. $500
Skunk2 Stage 1 Cams with Skunk2 Blue Cam Gears. -$350
SKunk2 Intake Manifold for B16. - $150 with all sensors
OMNIPOWER 70MM TB. $100 with all sensors
ITR Valve Cover moon cut for Cam gears. $125
ITR Distributor. $140
Or buy everything above $1200 no more than 5K on everything.
B17A1 Block
PR3 Pistons
ITR PUMP
ARP Head Studs
ARP Rod Bolts
MOTOR NEEDS NEW RINGS Compression is 210-170-170-210
Great for rebuild! RARE MOTOR!
$900
CLEAN TITLE 1993 Integra Shell.
1Piece Headlights
ITR Steering Wheel
Python REMOTE Start/Keyless Entry ALARM
Complete PALMY Blue Interior. VERY CLEAN for stock interior.
ITR Front Lip. Has some cracks but not to noticeable.
Car can use a paint job but still looks pretty decent for a 17YR OLD paint job.
WALBRO 255lhp Fuel Pump
Headlight wiring WIRE-TUCKED
Amber Bumper Lights
NEW Radiator with SLIM Fan
SKunk2 Shift Shifter
$1500 Everything mentioned above.
GT2871R Turbo
Greddy Type-S BOV
3" Spoolin DP
EARLS Fittings
3BAR GM MAP Sensor
Hallman PRO MBC
Greddy FMIC
B17A1 Block
PR3 Pistons
ITR PUMP
ARP Head Studs
ARP Rod Bolts
$900
1Piece Headlights
ITR Steering Wheel
Amber Bumper Lights
LooseboyEG6Tank
Jul 17, 2007 10:32 AM
LooseboyEG6Tank
Jul 8, 2007 10:24 AM
