Can I use 96-00 coilovers on a 92-95 civic?
Old Sep 5, 2010 | 03:25 PM
Black Diamond's Avatar
Default Can I use 96-00 coilovers on a 92-95 civic?
Was wonder if I can use 96-00 coilovers on a 92-95 civic..
Pretty simple question, i searched but couldnt find any thing but forsale threads.. So lmk honda-tech!
Old Sep 5, 2010 | 04:01 PM
98civdx's Avatar
Master Detailer
Default Re: 92-95 Civic Suspension Question
Yes, the fronts will work perfectly, you will just need to find a way to secure the brake lines.
The rears you will need to shave a bit of the lower control arm bushing, as the the 92-95is different from 96-00. A little more work would be to switch the 92-95 bushing for a 96-00 bushing.
Old Sep 7, 2010 | 02:59 AM
tercel95's Avatar
It might depend on the coilovers... I have Skunk2 Pro-S coilovers and they fit all 92-00 civics, 94-01 Integras... They come with a set of spacers to use on 96-00 civics in the rear due to the different size LCAs...
Old Sep 7, 2010 | 01:37 PM
98civdx's Avatar
Master Detailer
Your correct, theres quite a few compaines that are like this.
Old Sep 7, 2010 | 02:07 PM
Default Re: Can I use 96-00 coilovers on a 92-95 civic?
Cool thanks, i knew that for 92-95 civic sturts to work on a 96-00 you need spacers but i didnt know how it worked for 96-00 on a 92-95 civic. But thanks for the knowledge i thought i was going to buy some TEIN superstreets but i ended up buying something different,
Thanks again!
Old Mar 23, 2021 | 10:06 AM
Keyvan's Avatar
Is 96 an 01 coilover the same
Old Mar 23, 2021 | 12:06 PM
spAdam's Avatar
Loved
Community Favorite
Not even close
EL2
May 21, 2016 06:30 AM
ilovemydc4
Nov 20, 2007 11:26 AM
B16B_coupe
Suspension & Brakes
Aug 22, 2006 04:33 PM
chris_c
12
Dec 10, 2004 12:29 PM
