ED engine hood contact
I have a 1991 ED civic with a b18c swap. There is light contact between the hood frame and the valve cover, even the distributor gets nipped a little bit. I know I could probably use spacers at the hinges but I would like to keep the body lines. Has anybody had any luck with removing parts of the hood frame? If so what methods worked for you?
Take a piece of heavy wood, like oak. wrap it in an old blanket. open your hood, hold the wood on teh OUTSIDE (have a friend hold the hood open)
Bash at the webbing. Its there for structual strength, not looks.
I recommend this over cutting the webbing.
You still have a skeleton, and you now have some clearance.
Another option is to use HASport B series mounts, they move the motor towards teh firewall slightly to combat this.
Or you can buy a JDM style oem hood. USDM hoods come down in teh middle between teh fenders. the JDM hoods actually go UP.
yeah i tried bashing at it a little bit but i didnt have support on the other side, so the webbing wasnt really going anywhere. Ill have to give that a try. Thanks for your feedback.
just be careful
If you are a bit nervous about having a wrapped SMOOTH piece of wood, you can try using vicegrips, and twisting the webbing wherever you need it.
ill give that a try, thanks again for all the responses. I just needed a cheap fix...i dont really have enough money to replace hood or motor mounts. This should do it, ill let you know how it turns out.
C M S
Dec 11, 2004 03:05 PM
Black R
Jan 29, 2004 03:50 AM
