PnP k20a2 head w/ Valvetrain
Old Sep 5, 2010 | 04:21 AM
screaminvtec's Avatar
Default PnP k20a2 head w/ Valvetrain
SOLD
Old Sep 5, 2010 | 08:05 AM
eg_21's Avatar
Default Re: PnP k20a2 head w/ Valvetrain
how many miles on it?
Old Sep 5, 2010 | 11:17 AM
1500 miles on it.
Old Sep 6, 2010 | 02:22 PM
bump
Old Sep 7, 2010 | 04:00 AM
bump
Old Sep 7, 2010 | 04:02 AM
HPTautosport's Avatar
What CFM did it flow? Spring rates on springs? Hand ported or CNC?
Old Sep 7, 2010 | 05:36 AM
Rtboy10's Avatar
+30-40 cfm over stock, hand ported, usually the same spring rate evs spring is used for all ips k2 set-ups but I have heard of other rates being offered as well (when recommended rate ran out)
Old Sep 8, 2010 | 04:31 AM
first off thanks for the info Rtboy10. Been away from computer and good to know I can count on fellows members to fill others in.
As far as the spings this was from ips site
Optionally, Eibach EVS P/N 20411.216 has been certified.
Recommended for convenience, availability and more headroom to grow as you build the motor. Alternately, if stock bottom end is to be retained - the OEM valvetrain combo is ideally suited.
Eibach spring w/ Ti retainer
install heights & rpm limits:
@ 1.575" outer spring installed height - 9500+
(race only)
@ 1.590" outer spring installed height - 9300
(aggressive street/track) - good life
@ 1.610" outer spring installed height - 9000
longevity comparable to OEM combo, with higher rpm potential
Old Sep 10, 2010 | 04:00 AM
bump
Old Sep 14, 2010 | 12:16 PM
bump
Old Sep 15, 2010 | 10:20 AM
JDM_YANG's Avatar
nice...glws
Old Sep 18, 2010 | 05:05 AM
thank you
Old Sep 21, 2010 | 04:35 AM
bump
Old Oct 6, 2010 | 06:20 AM
bump
Old Oct 7, 2010 | 07:07 AM
bump
Old Oct 12, 2010 | 04:28 AM
bump
Old Oct 14, 2010 | 02:12 PM
bump
Old Oct 22, 2010 | 01:45 PM
bump
Old Oct 23, 2010 | 06:47 AM
kings**t's Avatar
hey whats up i just had a couple of ? for you about your head.
1.just asking but why does it look like cyc 2 on the exhaust was leaking oil?
2.where you loc at?
Old Oct 24, 2010 | 06:18 AM
pm'ed cyl 2 pic came out weird for some reason but all cyl look the same. no oil leak what so ever.
Old Oct 29, 2010 | 06:11 AM
bump
2jza780
Honda CR-V & Element
10
Apr 29, 2020 12:27 PM
vega5415
Suspension & Brakes
Feb 26, 2014 07:38 AM
patrickstar
Suspension & Brakes
Feb 17, 2009 11:49 PM
cjames235
Apr 19, 2002 05:00 AM
Superhatch
10
Feb 8, 2002 06:59 PM
