just check my compression
Old Sep 4, 2010 | 05:10 PM
usdmblackcivic's Avatar
Default just check my compression
Today i did a compression test on my r and she put down 220 210 235 235..... I did the test because she is smoking and i tryin to fig out whats wrong...ive had shops tell me its my value stim seals... im kinda lost and dont trust any of the shops in town...any help would be nice..
Old Sep 4, 2010 | 05:11 PM
BlueIntegraBoy's Avatar
Default Re: just check my compression
You need to do a leakdown test
Old Sep 4, 2010 | 05:13 PM
i have to look that up....ive heard people talking about that but never seen one done....
Old Sep 4, 2010 | 05:27 PM
just looked it up ...looks really easy the tool on the other hand is very costly...http://buy1.snapon.com/catalog/tools...e=snapon-store
Old Sep 4, 2010 | 11:56 PM
Quick99Si's Avatar
Harbor freight has a leakdown tester for $40. You still need an air compressor though. For now, you may consider adding a little oil to the cylinders w/ lower compression to see if there's a measurable increase. If your pressure normalizes across the board, then you're probably looking at a total rebuild due to worn oil or compression rings.
Conversely, oil burning can also be caused by worn valve seals or valve stem seals. Those are considerably faster and cheaper to fix, but from what you say, odds are faulty rings.
cryingsuns
Jul 28, 2013 10:21 AM
sirt_eg
Jun 16, 2009 01:25 PM
vinuneuro
Apr 25, 2007 10:13 AM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
Soled Out
Sep 9, 2003 05:08 AM
