motor mount for an eg
I have a 94 eg and it was auto n i changed it to stick shift n i just dropped a LS but my engine is not lined up does anyone know where i can get a custom motor mount to fix that problem
The frame mount is actually the difference, not the actual frame itself. Hasport makes the mount as well, or you could knock out the oem mount location (like a k-swap requires) and reweld a factory 5spd in place which would allow you to run a stock 5spd motor/trans mount. I say choose whichever option matches the mounts you have now, that's the route I'd go
Lei Siew Long
Sep 9, 2001 11:59 PM
