possible fuel problems? totally stumped
Hey guys ive been having a strange problem latly whenever i dump therefore peddle to the floor or when im about to hit vtec andpunch the gas the car bogs down or possibly fuel cuts and then goes is it possible i have a bad injector cuz. My fpr gauge at fuel throttle only shows 25psi on adjustable and on stock fpr thanks guys for the help
Possibly a bad fuel pressure regulator or it could be the fuel pump. If you say the fuel pressure is 25psi at full throttle that is way too low. The fuel pressure should go up at wide open/full throttle (low vacuum) It should be in the 46psi range. IIRC the idle fuel pressure should be between 35-42psi and at 3000 rpm it should be between 38-46psi. At idle when the vacuum hose is removed from the fuel pressure regulator the pressure should rise. If it doesn't move then there is more than likely something wrong with the FPR.
eg6king!!!
Jan 27, 2012 03:05 PM
cyrix12
32
Oct 24, 2006 07:42 AM
iNetForce
Nov 13, 2005 08:27 PM
