clutch pedaL IS STUCK ON FLOOR
Old Sep 4, 2010 | 10:45 AM
pereyragary's Avatar
Default clutch pedaL IS STUCK ON FLOOR
I HAVE A 1997 ACURA INTEGRA THAT I JUST RECENTLY PURCHASED BUT THE CLUTCH PEDAL IS STUCK ON THE FLOOR AND THE ONLY WAY I CAN MAKE IT COME BACK UP IS MANUALLY ANY IDEAS AND PICS ON HOW TO FIX OR WHAT CAN BE THE PROBLEM I REALLY WANT TO TGET THIS CAR ON THE ROAD THANK YOU ALL
Old Sep 4, 2010 | 11:38 AM
Drive 4 fun's Avatar
Default Re: clutch pedaL IS STUCK ON FLOOR
Is the clutch engaged or not, when the pedal is down; is the clutch functioning other than return?
Old Sep 4, 2010 | 12:24 PM
well i ended up bleeding the whole system and put some new dot-3 brake fluid re bleed it and now works......BUT......now there is another problem when im driving it it feels as if i had a flat so i got down and checked and there was no flats could this be the axles or is this something else any ideas please help!!!!!!!thanks
Old Sep 4, 2010 | 01:39 PM
I assume that you mean a flat spot in the tire, or some form of imbalance or vibration, not a rough or odd spot in the clutch mechanism. You may want to try a new thread with this new problem, people may not find your new question.
Old Sep 4, 2010 | 06:04 PM
SiR831's Avatar
Although you bled it already & the clutch is working now...check if the clutch master cylinder is leaking behind the clutch pedal at the floor board...If it's leaking than i'd recommend a new clutch master cylinder.
Old Sep 4, 2010 | 08:33 PM
thanks everyone and thanks for the idea of starting a new thread
B18Redline
Nov 13, 2007 11:09 AM
icemanxlb
Jun 27, 2007 06:23 AM
Sinner
Apr 27, 2006 10:44 AM
2ksi
Aug 12, 2003 04:45 PM
