distributor is making noises.
Old Sep 4, 2010 | 05:31 AM
rondogg779's Avatar
Default distributor is making noises.
went on a long road trip yesterday and i had a heater hose bust and the thermostat was sticking.after replacing these things i drove about 100 miles then stopped at a gas station and realized the distributor was making noises.it sounded somewhat like a duck call and was loud.if you held your hand on the distributor cap you could feel it when it mad these noise it was kinda of grinding.i was just wondering if anyone had run into this problem before.this is a first for me.
Old Sep 4, 2010 | 05:39 AM
joe_accord23's Avatar
Default Re: distributor is making noises.
u need to change it, soon, it will give out. so listen to it!
Old Sep 4, 2010 | 08:33 AM
rondogg779's Avatar
im listening to it lol,but i dont have the cash to switch it and i cant find one at the junkyard.are any of the other distributors compatible?im going to take it apart and see what it is maybe i can get away with swapping the rotor.
Old Sep 4, 2010 | 08:50 AM
hondawhiz's Avatar
sounds to me like the shaft is sticking. after this its going to start making more noise, and make ur car slower, because its getting stuck to itself. where are you located. i have a couple dizzys for cheap.
Old Sep 4, 2010 | 09:06 AM
rondogg779's Avatar
charleston sc.are any other ones compatible with the h22a?so i should just replace everything and i should be good right?
Old Sep 4, 2010 | 09:09 AM
hondawhiz's Avatar
if you can get to the bearing, you would literally have to rebuild everything. but you dont need anything new electrical.
Old Sep 4, 2010 | 09:25 AM
rondogg779's Avatar
so it is probably the bearings.cool i will put up a video in a little while if it is still doing it.advance has a remanned dizzy for like $126.but a buddy of mine has a 01 prelude that the transmission went out on.i could probably get his but im not sure if it will work.my motor is obd1.
Old Sep 4, 2010 | 09:42 AM
hondawhiz's Avatar
wont work from that lude.
Old Sep 4, 2010 | 10:33 AM
rondogg779's Avatar
ok,im going to look around and see what i can find.
hondacivic90zc
May 18, 2008 10:53 AM
Go_Kart_Driver
Apr 17, 2007 01:28 PM
davekaro
Apr 3, 2004 02:38 PM
Spoonin
Jun 28, 2003 01:47 AM
AK94GSR
Feb 24, 2003 11:39 AM
