Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
fuel Schrader valve location
Old Sep 4, 2010 | 12:46 AM
bigufofoot's Avatar
Default fuel Schrader valve location
Hey there I own a 2003 Honda Accord V6, looking to put a Wet nitrous system in place. Before I buy the nitrous I wanna do research and make sure that the nitrous will work with my car. I was wondering if anyone knows the location of the Fuel Line Schrader valve on my car... All I found was a EVAP valve which I am sure isnt the right one.. Thank You
Old Sep 4, 2010 | 04:50 AM
LPED's Avatar
Default Re: fuel Schrader valve location
AFAIK Honda does not have/use Fuel Line Schrader valves . Honda fuel system is a pump and regulator in the tank , no return lines from injector rail, just the fead line and Honda keeps constant fuel pressure across the engine load (no fuel regulator with vacuum port). AFAIK fuel pressure is around 52lbs .
Old Sep 4, 2010 | 11:29 AM
bigufofoot's Avatar
Oh i see, could you suggest a nitrous kit that would work with my car?
Old Sep 4, 2010 | 12:22 PM
LPED's Avatar
Sorry i am not up on nitrous on Honda's but if you just needed the Schrader valve for the tee off for fuel solenoid . The just make a tee in the fuel feeder(metal lines) to fuel rail somewhere and do all the rest the same.
Old Sep 4, 2010 | 10:11 PM
bigufofoot's Avatar
alright! cheers m8! thanks for the advice! really helpful!
dominidg123
Jun 2, 2009 05:42 PM
fast forward driver
Mar 29, 2007 06:29 PM
honda3x23
May 12, 2006 09:08 PM
mstewar
29
Mar 28, 2005 11:11 AM
My_Blk_Si
Apr 14, 2003 09:04 AM
