Popping noise when depressing brake pedal?
Old Sep 18, 2002 | 05:06 AM
mycivicstoo(s)low's Avatar
Default Popping noise when depressing brake pedal?
I have a 94 Civic EX without ABS and for about the last week when I use the brakes there is weird popping noise coming from the driver's side brakes. It happens immediately after I touch the pedal. It happens even when the car is stopped so it's not the axle/cv joint. And everything feels the same; no pulling or anything like that. Has anybody had this problem or have any idea what it could be? Thanks.
Old Sep 18, 2002 | 10:24 AM
Default Re: Popping noise when depressing brake pedal? (mycivicstooslow)
Ok guys, hope I don't lose control and hit a school bus full of children or something. j/k
Old Sep 18, 2002 | 10:39 AM
SyndicateEH's Avatar
make sure you wear your seatbelt!
Old Sep 18, 2002 | 10:44 AM
Default Re: Popping noise when depressing brake pedal? (SyndicateEH)
Thanks for your concern. I will. I'll just use the handbrake instead.
Old Sep 18, 2002 | 07:20 PM
Simple's Avatar
could it be your shocks? my gurlfriends car makes a popping noise, but it comes from the back, but its everytime she hits the brake too, and its the shock.
Old Sep 18, 2002 | 07:31 PM
Default Re: Popping noise when depressing brake pedal? (Trey94DX)
Nah, 'cause it even happens when I'm sitting still.
Old Sep 18, 2002 | 07:40 PM
Simple's Avatar
how about air in the lines? maybe why it makes the popping noise? im just tryin to throw out ideas.....
Old Sep 18, 2002 | 07:42 PM
I'll put that on the list of things to check in the morning. Thanks.
Old Sep 18, 2002 | 08:01 PM
tooqwik1's Avatar
yea might be the springs do u have coilovers?
Old Sep 18, 2002 | 08:06 PM
Dr. EKology's Avatar
Default Re: Popping noise when depressing brake pedal? (tooqwik1)
i got the same problem too! Almost everytime i hit my brakes it makes a hard clicking noise, like a pin or something is snapping into place. Any ideas??
Old Sep 18, 2002 | 08:38 PM
Default Re: Popping noise when depressing brake pedal? (EKology)
My car has stock suspension and brakes, and it happens when I'm stopped too so it can't be my suspension. It keeps popping when I push the pedal lightly and am moving slowly. I don't know if it happens at higher speeds because I can't hear it over the engine. It's also easier to hear from inside the car because the engine drowns it out outside the car.
Old Sep 18, 2002 | 08:40 PM
PhuckinHondas's Avatar
it might be that there is to much play in between the brake pad and caliper
you could get some grease and grase where ever the pad make metal to metal contact grease the end of the piston (where it makes contack with the pad)
good luck
Old Sep 18, 2002 | 08:42 PM
Default Re: Popping noise when depressing brake pedal? (In The 16s)
I'll check that too, thanks.
Old Sep 18, 2002 | 08:48 PM
let me know if it fixed it
my friend had the same problem and i just put brake grease on those parts and it fixed it
Old Sep 18, 2002 | 08:51 PM
seano's Avatar
If its an automatic, then it will pop everytime you push the brake because it releases the shift lock
Old Sep 18, 2002 | 08:52 PM
Default Re: Popping noise when depressing brake pedal? (seano)
that would only be in park, not when its in gear. Nice avatar though...cracks me up everytime i see it! lol
Old Sep 18, 2002 | 08:56 PM
It's manual. I'll try the brake grease in the morning. I'll do some more listening and see if I can be more descriptive. Thanks.
[Modified by mycivicstooslow, 11:02 PM 9/18/2002]
Old Sep 18, 2002 | 11:51 PM
deviant1's Avatar
i have a click sound that comes from my front discs whenever i put it in reverse and step on the brakes the very first time while going in reverse. one of my friends said the brake pads may be loose. i dunno, but check your pads and rotors.
Old Sep 25, 2002 | 09:04 PM
NERV's Avatar
I have the same problem. It pops everytime I hit the brakes. It seems to be on and off problem. Anyone know how to fix this?
Old Jul 6, 2007 | 06:50 PM
usmarinedelta's Avatar
* B A N N E D *
Default Re: Popping noise when depressing brake pedal? (NERV)
any fixes to this because I'm having the same problems and it's scaring the hell out of me.
Old Jul 7, 2007 | 02:03 PM
* B A N N E D *
bump
Old Jul 7, 2007 | 05:21 PM
* B A N N E D *
Default Re: (usmarinedelta)
gonna bump forever!
Old Jul 7, 2007 | 06:49 PM
quicksilver1689's Avatar
i ♥ snails
maybe it has to do with shims on the brakepads or lack of them?
nonohood69
Jun 12, 2013 07:09 AM
GAngulo7
Honda Civic (2001 - 2005)
Jan 26, 2010 08:17 PM
StockEm2
Suspension & Brakes
Jun 18, 2009 11:10 PM
ITR#132
Feb 4, 2003 08:22 PM
