2 problems/questions about my b16 build ..
Old Sep 3, 2010 | 10:49 PM
EF9_TryMe's Avatar
Default 2 problems/questions about my b16 build ..
1. for the threads on the back of the crankshaft where the fly wheel goes, what size heli coil, drill bit, and tap do i need to get to make a new thread pattern in there ? Im rebuilding my motor, and i took the tranny off, as i took out the flywheel bolts, one of the threads inside is jacked up...
2. on my third piston connection rod cap, it would fit in too tight. i had to shave down the side of the cap just a tad little bit in order to prevent the motor from seizing everytime i turned it over to check if it was binding. i took the cap off and sanded down the sides a bit, now it's got a little bit of play when i move the cap from side to the against the crank at bdc.. not alot, just a tiny bit not even a mm. Is this alright ? Would I still be able to run it without a problem ?
Old Sep 4, 2010 | 10:28 AM
EF9_TryMe's Avatar
Default Re: 2 problems/questions about my b16 build ..
bump, anybody have any ideas ?
Old Sep 5, 2010 | 11:40 PM
EF9_TryMe's Avatar
bump.
Old Sep 7, 2010 | 08:08 PM
EF9_TryMe's Avatar
bump.
BlaccPlasticc
Jul 31, 2010 01:19 PM
1990tegg
Aug 5, 2008 06:53 PM
biotech0123
Sep 6, 2006 07:35 AM
B00STED Si
Aug 30, 2005 06:02 AM
magic hat #9
Dec 30, 2002 07:12 PM
