my speedometer is going crazy
Old Sep 3, 2010 | 07:42 PM
CivicSi95's Avatar
Default my speedometer is going crazy
i have a 95 si and the speedometer is just bouncing around randomly. it will read the correct mph for a little bit and then go haywire. i have replaced the cluster with another good condition cluster and it still is going crazy. i also am not throwing any CEL.
Old Sep 3, 2010 | 08:45 PM
Sprmario's Avatar
Default Re: my speedometer is going crazy
did you check your VSS? The plug that connects to it could get wet if you just cleaned out the engine bay, i would set d/c the plug make sure its dry and check again. Also my cluster would do that before the car would shut off on me and found out that my ALT,VSS fuse under the dash was out and i was running the car with only the battery, but my cel did light up. I would check fuses to start then the plug
Old Sep 3, 2010 | 09:46 PM
alacard's Avatar
Any other electrical issues? May be worth checking your grounds.
Old Sep 3, 2010 | 10:01 PM
Arthas's Avatar
Mines doing the same thing... For a while, it died completely. I changed the tranny fluid but right after it just started bouncing around.
Old Sep 4, 2010 | 12:26 AM
contra's Avatar
Try checking your speed sensors. Experienced that before.
Old Sep 4, 2010 | 06:43 AM
CivicSi95's Avatar
i was unaware that there is more than 1 speed sensor. where is the other one located?
Old Sep 4, 2010 | 07:53 PM
kazimkazi's Avatar
where is the vss 96 civic ex
jumpin4abeat
19
Apr 15, 2017 01:02 AM
madracer
39
Aug 11, 2010 09:54 AM
xiapher
Dec 14, 2009 11:25 PM
xJ.SLOTHx
May 10, 2004 10:03 AM
cegleitz
10
Jan 31, 2004 09:39 AM
