b18c1 into a 92 civic si - which ecu?
I have a 92 Civic Si with a 96 b18c1 swap. A 97 GSR engine harness is what I'm using because it hooks right up to the Civic's shock tower. Inside is a socketed/chipped p72 ECU with a p72 base map. Issues with this:
-No cold start.
-Engine is sluggish 5000-6000rpm when accelerating.
I tried putting in p30 base map I had laying around just to see how it would do. Issues with this setup:
-No cold start.
-Fuel pump cuts off and on when I'm doing 70-75mph.
I then borrowed a friends stock p28 ECU and hooked it up. Issues with this setup:
-No cold start.
-Can't pass 7500rpm.
Before I spend any money, I just need to know what ECU to get or what base map to get for the p72. Thanks for your help HT.
-No cold start.
-No cold start.
-No cold start.
My friend's car runs fine. I don't have any way of checking for codes. I was leaning towards the ecu being the problem because the fuel pump cut off and on depending on which ecu I use. Stock p72 doesnt do it where as the stock p28 does.
The revlimit on a stock p28 is 7500 rpms.
Concerning a fuel pump cutting off at a specific speed like 70-75 mph I have never seen anything like that before.
