whats better 1000cc injectors peak and hold or saturated
Old Sep 3, 2010 | 04:15 PM
b16bri's Avatar
Default whats better 1000cc injectors peak and hold or saturated
I herd injectors dynamics or who ever came out with a set of 1000cc high impediance saturated injectors. Does anyone have any experience with these is it' better to run these over lets say a set for percision or RC 1000cc low-impediance and the use of a resistor box ?
Old Sep 3, 2010 | 05:14 PM
HiProfile's Avatar
Default Re: whats better 1000cc injectors peak and hold or saturated
1k precisions suck no matter what. At the point you get a resistor box installed, you'll have more time and money involved than just getting the ID's.
Old Sep 3, 2010 | 05:36 PM
b16bri's Avatar
i'm confused why do they suck and i herd 1000cc sat injectors were garbage ? and not reall 1000cc
Old Sep 3, 2010 | 08:17 PM
ROMEO856's Avatar
im using precision 1000cc injectors and havent had any problems... i will be switching them for some id 1200-1600cc for my new build thou.
Old Sep 3, 2010 | 08:35 PM
jetspeedz's Avatar
ID1000's are great injectors, switched from RC to ID and can't be happier, no need to worry about resistor box and flow very well.
Old Sep 3, 2010 | 09:24 PM
habib's Avatar
ive used the precision 1000cc injectors and switched to the id 1000cc injectors and love them, no need for the resistor box and a smoother idle with them
Old Sep 3, 2010 | 09:25 PM
tony413's Avatar
1000cc low impedence injectors are nice if you have a resistor box or the even better injector driver, because then you dont have to upgrade your whole fuel system.
1000cc high impedence injectors require you run a higher base pressure and that may involve redoing your fuel system BUT you dont need a resistor box or injector driver. also they will work like stock once you do your part.
Old Sep 4, 2010 | 09:55 AM
b16bri's Avatar
it will be on a built motor anyways so the fuel rail and pressure regulator will be upgraded along with at least a walbro 255 if not the addition of a inline bosch not sure about the bosch but will the rail and reg and walbro be enought to run tghe higher pressure ? also this is a jdm b16 going in a 1998 civic these injectors should just be plug and play right
Old Sep 4, 2010 | 01:23 PM
tony413's Avatar
talk to tony1 he can get you squared away but heres the basic
walbro intank feeding to a bosch 044 inline you need a good FPR to as you will need to run over 60psi base pressure i think its like 70-80psi but i dont remember.
Old Sep 4, 2010 | 04:03 PM
b16bri's Avatar
how do i get a hold of him
Old Sep 4, 2010 | 04:25 PM
KStuned's Avatar
Call him, that usually works.... (214) 607-9022
Old Sep 5, 2010 | 08:31 AM
heavy duty's Avatar
I had a set of 1600s and i hated driving it and bought the id1000 and love it. O and i all so picked up 60hp at the same psi.
Old Sep 5, 2010 | 02:53 PM
97hb's Avatar
Had both, PTE 1k's and now the ID 1k's. Buckin is a thing of the past now, lol. Stock FPR here also. Super smooth part throttle driving.
Steeve_Civic
Dec 4, 2011 10:11 AM
columbushatch
Jan 17, 2009 11:08 AM
civicsaremean
Jun 29, 2007 06:17 AM
boost_is_best
Feb 28, 2006 03:45 PM
thid92
Aug 10, 2003 08:23 PM
