h23 crank pulley on h22?!
Old Sep 3, 2010 | 09:50 AM
liljimmy14's Avatar
Default h23 crank pulley on h22?!
ive been searching about whether you can use a h23 crank pulley on a h22 and people are saying the h23 has an extra rib in it and some are saying that the h23 pulley is balanced for the h23 crank and not the h22. the reason im asking is because a h23a2 landed itself in the junk yard today so if i can salvage it from there then i will, save myself £100!! i have a h22a5 with manual belt tensioner conversion as well. will this also cure the tightness of the tension conversion?
Old Sep 3, 2010 | 10:40 AM
mrbleegs's Avatar
Default Re: h23 crank pulley on h22?!
H23 crank pulley has an extra rib on the part that runs the alternator and AC pump, the power steering part has the same amount of ribs.
Old Sep 3, 2010 | 10:49 AM
liljimmy14's Avatar
ok thanks, any idea whether it is compatible with the h22 engine?
Old Sep 3, 2010 | 11:14 AM
snobordboy's Avatar
Moderator
Yes, I have an H23 pulley on my H22, have for 4+ years
Old Sep 3, 2010 | 11:36 AM
liljimmy14's Avatar
cool so you think i should go for it? bearing in mind i have an h22a5 eudm engine? and i take it you use h23 aux belts?
Old Sep 3, 2010 | 02:18 PM
the boogler's Avatar
since the h23 pulley has an extra rib, the a/c and the alternator pullies will also have an extra rib. so if u wanted to use the h23 crank pulley you would have to use the h23 a/c and alternator pulley as well, along with the h23 belts.
as far as the balancing with the crank goes.. i have no idea
Old Sep 3, 2010 | 02:39 PM
liljimmy14's Avatar
ok....hmmm im sensing difficulty already, getting the pulley of my alternator is going to be a struggle!! any tips for this?
Old Sep 3, 2010 | 05:39 PM
mrbleegs's Avatar
To get the altenator pulley off take it out of the car. Hold the pulley with you hand wearing a work glove and then use an impact gun on the pulley bolt at 150psi and ZIP... it will come right off easy, guaranteed.
Old Sep 4, 2010 | 03:00 AM
liljimmy14's Avatar
Ive only got a 440nm dewalt impact wrench, i'll have to give it a go with that. Thanks for your help! Much love
snowblind7x
May 13, 2007 11:51 PM
user 720822-1
Apr 20, 2007 06:11 AM
paulwithap
Jul 20, 2006 12:42 PM
blacklude94
Nov 14, 2005 04:08 PM
4bidden
Apr 26, 2002 06:19 AM
