Valve Adjustment - Why do it?
I know that I should know this. I also know that I should have done it before.
However, with 360K+ on my 92, it has never been done unless somebody broke in to my garage and did it.
The car still runs strong and has good power (well, as much as it ever had). It has dropped from 28-28.5MPG to about 24-24.5MPG over the many years, but I just figured that it was old.
I can easily do this, but why should I? What does it help?
I am ashamed to even have to ask this...
my 90 gets 33+.
the valve adjustment is the clearance between the rocker arm and the cam shaft. if the clearance is too tight the cam could be opening too soon or not closing all of the way. Same goes it is too loose. It could be opening late and not to the correct lift reducing power. both could very easily affect gas mileage.
My friend had a shop do it on his RSX-S for $90 and it made his idle noise much quieter and he gained quite a bit of power and MPG's.
@$90 with a 360k engine, I dont see why not.
It is an often neglected maintenance item that does wonders. It is a critically measured job that has a feel qaulity that untrained people could easily mistake and cause serious problems. So unless you feel comfortable doing a valve adjustment I would pay to have it done. You can usually lessen your expense by bringing your own valve cover gasket set including tube seals and valve cover grommet kit.
Took 45 minutes and did this tonight. Noise is WAY down and even if nothing else changes, it was worth it.
It appears to be pulling over a pound more of vacuum that it did last week. It shifted earlier, so I wonder if the TCM gets vacuum readings. It ran down the road smoother, but if it had more power, it was negligible.
The clearances were anywhere from .018 to .024.
I messed up something - it has a bit of a chug at idle and you can hear it in the exhaust. I probably need new feelers (and another time for experience) - they are copper and worn a bit. I will fix it this weekend. Is this a symptom of them being too close? My book said .007 for the intake and .009 for the exhaust, right?
From: Where haters hate on haters for hating, Louisiana
And don't tighten the bolt all the way down on the feeler, leave some play. How do we know what engine you're working on?
Valve timing is critical. Natrual valve overlap is taken into account when writing the fuel mapping software for the vehicle. This is also used to create a natrual EGR effect and reduce engine temps and NOx creation. Valve clearance can affect engine vacuum which in turn affects fuel mapping. Lack of valve clearance can cause misfires and engine damage. Too much clearance can cause damage to the cam shaft lobes and rocker arms. There are more reasons valve clearance adjustment should be set correctly but these are a few.
I got it. I had one set of exhausts that were too tight - no clearance and probably not seating all the way. I have no idea what I was doing there.
I am happy now - running great and quiet valves.
Greetings, Honda Newd but car familiar...
Scored a 97 accord EX-L with the F22B1 VTEC 5 spd yesterday for a can't pass price.
Anything "tricky" about this valve adjust besides what posted in how to?
The 10mm
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-adjust-valves-your-f22-2477017/
Alot of useful information is in the FAQ's sticky at the top of this forum.
Eric the car guy on youtube has a great video on it. Made me wanna try it but I dont wanna mess up my car. Its for good measure and relatively straight forward.
Apparently Hondas are pretty good about not needing the adjustment though.
The SOHC motors don't need it as often as the DOHC motors, but if you're handy with your tools it doesn't hurt to do it. Just don't rush it...just take your time or don't do it at all.
