intake air temp?
Old Sep 3, 2010 | 06:27 AM
ama11's Avatar
Default intake air temp?
on my hondata it says my iat is around 238 or so and i thought that was hi but idk. just wondering if maybe it was bad or if there was a way to fix this?
Old Sep 3, 2010 | 08:28 AM
boostedteg1203's Avatar
Default Re: intake air temp?
Yea, normally 120 is high! We stop doing dyno pulls if it gets above that. I'd check the sensor.
Old Sep 3, 2010 | 10:49 PM
slowtegkauai's Avatar
could it be from heat soak? If you run your car for a while then turn it off and let it sit, the sensor gets hot from all the heat the engine generated. Then when you start it the s300 will see a high temp because its soaked up all the heat from the motor to the intake manifold. Depending on what you set the air temp/ fuel perameters it will eather lean or richen the fuel mixture.. mostlikely lean tho. because hot air is less dense thus needing less fuel to burn a stoichiometric AFR. But in reality, cold air is going into your motor and the computer is sensing false hot air because it is heat soaked.
just a thought.
Old Sep 6, 2010 | 10:21 AM
ddd4114's Avatar
Are you boosted? If so, what compressor and what size intercooler are you using? When did you see that reading?
I've been monitoring my IAT for over a year, and the highest I've seen is about ~165, sitting in traffic on a hot day.
MooreBoost
Aug 31, 2008 05:52 AM
RA081523
Feb 27, 2007 07:29 PM
charjacq
Nov 25, 2002 06:43 PM
Razor
Jan 26, 2002 10:05 AM
