Code 5 MAP sensor help!
Old Sep 3, 2010 | 05:00 AM
Monstarrr*'s Avatar
Default Code 5 MAP sensor help!
Okay, after swapping a b16 motor into my eg hatchback, it threw a code about the map sensor (light blinks 5 times). Changed it and got a map sensor from an ls motor cause i figured that if i had obd0 ls throttle body then i should have ls map sensor. The motor works fine, but it bugs me that the light is still on. Anyone can help me on this situation. Thanks
Old Sep 3, 2010 | 06:04 AM
Former User's Avatar
Default Re: MAP sensor help!
Was the original MAP sensor in your hatch mounted on the firewall? If so, is the MAP sensor connector possibly still plugged into the old MAP sensor?
Old Sep 3, 2010 | 06:54 AM
Monstarrr*'s Avatar
No the original map sensor was mounted on the VX throttle body. From what ive been told, the ls map sensors were mounted onto the chasis firewall, so i connected a tube from the map sensor to the throttle body. It runs fine, but i want to get rid of the check engine light. Is it cause i have a p28 computer? my old po7 ecu didnt read this until i changed my ecu.
Old Sep 3, 2010 | 07:36 AM
Code 5 would be thrown if there is a vacuum leak at the MAP sensor or the hose or its connections.
Old Sep 3, 2010 | 08:26 PM
Monstarrr*'s Avatar
Default Re: Code 5 MAP sensor help!
Alright ill change the tube, ill let you noe, thanks.
snidbits
Feb 11, 2011 03:19 PM
eg93LS
Jun 10, 2009 08:51 PM
liftdhatch95
Feb 9, 2008 02:00 PM
92ehatch
16
Feb 19, 2007 11:41 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
