Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Misfire code on 05 MDX
Old Sep 3, 2010 | 12:52 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Misfire code on 05 MDX
2005 MDX runs rough, hunting idle. misfire codes on all banks plus random misfire code. evap monitor ready occasionally. what could this be? plugs replaced, EGR valve and passages cleaned.
Old Sep 3, 2010 | 01:13 PM
Duane_in_Japan's Avatar
Default Re: Misfire code on 05 MDX
What spark plugs are you using now and before the change. Use only OEM brand and specific heat range is the correct answer. Since you have the ability to monitor misfire, now once we have the correct spark plugs installed, you will want to monitor short and long term fuel trims, MAP voltage at idle and the O2 sensor voltages at idle and at a steady cruise.
Let us know what you find.
Old Sep 17, 2010 | 04:03 PM
i am using the cheap autozone plugs. i shall replace them with OEM equivalent. i do not have any ability to check fuel maps nor read the voltages off the sensors. i simply have an ODB2 reader. i have heard these engines are very sensitive to the spark plugs.
Old Oct 3, 2010 | 07:32 PM
J_DC5's Avatar
Yes they are only use OEM plugs and see which cylinder misfires first swap the coil to a different cylinder on the other bank and see if it followes .
this is the cylinder order 1 2 3
4 5 6
Old Oct 12, 2010 | 12:43 PM
1.7na's Avatar
How many miles on your MDX? Maybe it needs a valve adjustment. I have 95K on my 03 and also had cylinder misfire codes on all cylinders as well as rough idle until it is fully warmed (also swapped our the EGR valve thinking that was the problem) Dealer indicated that I need a valve adjustment and said it is not unusual that it will cause it to throw a code.
Old Jan 28, 2011 | 02:16 PM
It was exactly that. After checking the specs on clearance most exhaust valves were extremely tight. The adjustments cleared the issue. It is a relatively easy procedure to do as well.
ZXiPoZ
May 12, 2012 10:28 PM
92jdmhatch
Honda S2000
20
Sep 5, 2006 04:33 PM
sidewayz32
Sep 28, 2005 10:14 AM
1.8t
Dec 19, 2003 03:27 PM
shahram72
Dec 19, 2002 10:49 AM
