880cc injectors too little?
Old Sep 2, 2010 | 06:45 PM
sh!ft's Avatar
Who the fack changed my title?!
Default 880cc injectors too little?
im going to be running 15lbs MABE more(depending on how the tune goes) and i wanted to know if 880cc precision injectors are too small of a size injector. they also need a resistor box as well.
Old Sep 2, 2010 | 07:32 PM
TurboChurch's Avatar
Default Re: 880cc injectors too little?
And you left out alot of things needed to answer your question, what engine? Turbo or what power are you shooting for? What fuel pump/pumps do you have, adjustable regulator?
Old Sep 2, 2010 | 07:38 PM
andrew54's Avatar
yes you will need an resistor box or in line resistors that will work with your power goals in mind. I have 880s with inline resistors to im running 19.2lbs 440 whp, but im going to get the injector dynamics 1000cc injectors they dont need the inline resistors or resistor box
Old Sep 3, 2010 | 09:17 AM
welfarepc's Avatar
i made 450whp on precision 788 low impedance injectors with a stock 1:1 fuel pressure reg. they were pretty much maxed out.
Old Sep 3, 2010 | 01:47 PM
blackeg's Avatar
wow, most informative initial post ive ever seen.....i think im getting too old for this
yes you will need a resistor box. ive been making low to mid 400hp range on 880s stock pressure pump gas for a few years with no problems. i had a friend make 598whp on c16 with 880s i think running 60psi base. lol they were at like 98% duty cycle so the car was scaled back to 550whp.
for the record, this has nothing to do with boost pressure, and everything to do with cylinder pressure, torque and resulting horsepower
Old Sep 3, 2010 | 07:36 PM
sh!ft's Avatar
well thats what i initially thought. as far as compression goes etc.
Old Sep 4, 2010 | 07:01 AM
Schister66's Avatar
Man U FTW
Me too....i'm not even going to answer either...
Old Sep 4, 2010 | 09:15 AM
sh!ft's Avatar
then why post in here?
CivSiClone_96
Dec 20, 2009 05:52 PM
skeetahendo
Mar 15, 2008 03:44 AM
DrivinVtec
Sep 17, 2007 10:08 AM
gtturborex
Sep 1, 2005 08:26 PM
evilcivilian
Oct 6, 2004 10:04 PM
