75K Maintenance
Old Sep 17, 2002 | 11:44 PM
EminemGSR's Avatar
Default 75K Maintenance
I left my Helms manual at my other house. Can someone please post what is involved and what to change for my 75K maintenance?
Thanks
Old Sep 17, 2002 | 11:47 PM
Reid's Avatar
Global Moderator
Default Re: 75K Maintenance (EminemGSR)
Wrong forum.
Old Sep 18, 2002 | 12:16 PM
EminemGSR's Avatar
Default Re: 75K Maintenance (Reid)
How in the world is this the wrong forum? I see so many OT questions asked here yet mine is labeled as the wrong forum???
Old Sep 18, 2002 | 12:36 PM
Sima's Avatar
Here you go...
[B]15k/45k/75k mile service[B]
Change Engine Oil & Filter
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Inspect Front & rear Pads, Rotor & calipers
Inspect all fluid levels
adjust parking brake
inspect clutch operation, adjust freeplay and check fluid level condition
adjust all belts
inspect suspension mounting bolts for tightness
inspect exhaust system
inspect tire wear and set tire pressure
check hoses belts and coolant level
inspect battery and clean terminals
adjust alternator belt
inspect valve clearance
check wiper blades and winshield washer fluid
lube door, hood latches and hinges
rotate tire and balance
inspect and clean spark plugs
inspect cap and rotor
road test
Old Sep 18, 2002 | 03:23 PM
EminemGSR's Avatar
Default Re: 75K Maintenance (Sima)
THANK YOU Sima. I dont remember the htech community being rude as in the previous posts. Also, since when are tranny fluid changes glorified? That is amusing.
Old Sep 18, 2002 | 03:31 PM
ZygSpeed's Avatar
Maybe we just don't like Eminem!?
Old Sep 18, 2002 | 05:34 PM
BudMan's Avatar
Default Re: 75K Maintenance (Zygspeed)
I do, I do .... never mind Ed - it's the daquiri's taking over
RNPoo7
Aug 21, 2005 02:05 PM
io_burn
Aug 20, 2003 02:29 AM
uNF$@#!
Mar 1, 2003 08:10 PM
SonicGSR
Oct 9, 2002 08:16 PM
SonicGSR
Oct 9, 2002 07:28 PM
