Rear balance shaft gear removal
Old Sep 2, 2010 | 01:40 PM
erottik-R's Avatar
Icon6 Rear balance shaft gear removal
A friend of mine is trying to remove the oil pump to re-seal between the pump housing and engine on a 1997 Accord with a F22B2 engine. He's at the point to remove the pump housing except that he can't get the rear balance shaft gear off. He removed the bolt but the gear won't pull off and there is no room to get standard gear puller jaws beneath it. Is there another way to get it off or does Honda have a special puller? Any advice or information would be much appreciated.
Thanks
Old Sep 2, 2010 | 01:59 PM
GhostAccord's Avatar
Default Re: Rear balance shaft gear removal
There aren't any special pullers that I know of. Mine pretty much fell off. If it's stuck on there just give it a few love taps with a rubber mallet @ 12, 6, 3 & 9. That should help wiggle it loose.
Old Sep 2, 2010 | 07:40 PM
HonBeer's Avatar
Friend? Just admit it it is yourself that needs the help. Your "friend" has a computer. Ask your "friend" to get on the net nd ask himself. If Your "friend" really exists.
Old Sep 3, 2010 | 05:11 AM
erottik-R's Avatar
Listen smarty. I drive a 2000 Type R as my signature suggests and my friend DOES NOT have a post account here on Honda Tech. It is kind of hard to crawl out from under a car and go through the registration and 5 post minimum process just to get a quick answer.
Whether you choose to believe it’s me or not is frankly BEYOND my realm of care.
If you do have a helping answer I’ll be very glad to get to hear it. If not it would seem smarter to use a lot less energy and just ignore my post.
Thanks to the other who responded.
And just so hot ‘BEER’ gets poured down your butt crack:
Here is my friend’s post on a site he has a registered account.:
http://hondaaccordforum.com/forum/sh...975#post214975
Old Jan 10, 2024 | 10:20 AM
cohesion's Avatar
For anyone in the future still struggling with this. But before you do anything make sure you have a long bolt to lock the rear balance gear.
Yes, I just got mine off this second. You wont have clearance for rubber mallet. I used a long piece of wood and hit with a hammer on the bottom portion near the bottom bolt hole. You free it from the bottom and you can finally kind get it from the top. I didn't need to hit anything from the top because I didn't have clearance anyway. You will notice if you are getting it. It will start leaking motor oil. And you are starting to free it from it's matting surface. Just keep wiggling it back and forth and it will come off.
Stopsign32v
Mar 8, 2016 11:41 PM
mfrs
Feb 20, 2014 07:42 PM
mouab18c1
Jun 14, 2013 02:11 AM
gregb96accord
May 28, 2013 04:52 PM
pleej
Sep 9, 2009 10:56 PM
